Help! More Camber Needed!
Posted 21 October 2003 - 07:54 AM
Posted 22 October 2003 - 11:24 AM
Steve
Posted 22 October 2003 - 11:35 AM
interesting...0,7 and 1,3 with all shims removed...did you come up with such measurments WITH yourself on board?I need to remove the last shim, which serve as a holder for the ABS sensor wiring connector. Since the bolts are recessed I can not place a holder under the bolt head. And if I clamp the wiring to the suspension upper arm, there will be movement between the sensor and the connector.
The reason for my troubles is that if I remove all shims I get 0,7° on the left side and 1,3° on the right side. I don´t whant to place a shim on the right side giving approx. 0,7/0,7 L/R, instead I want the more extreme 1,3/1,3 L/R. Anyone?
afaik the only solution is to remove the hub and grind away an extra 1mm thickness.... or more!
...lizzie owners do that customarily...
about the ABS sensor, I've been thinkering about it for quite some time, but still unresolved how the secure it safely...
steve, about adding below, its impossible I think, only a joint ball IIRC
Posted 22 October 2003 - 12:40 PM
Posted 22 October 2003 - 02:51 PM
in order to get a realistic and effective reading, exp. for sportscars, the driver should always be on board, with a pax along (if the racing is done with a pax)No, I was not on board (?!) The measurement were made at a tyre shop and should be accurate, since it is a computerised system, but who knows
values can (and will) swing around quite a lot with an extra 80kg on one seat...
Posted 22 October 2003 - 03:00 PM
Posted 22 October 2003 - 03:08 PM
above 80 kg?!? heck YEAH it will make a difference!!!Pax? Passanger? And 80 kg is too little in my case, no love handles though
Maybe that could save the situation, since that will automatically give more camber on the driver (left) side
...you must be one of those huge, blond vikings, huh?!?
deffo you'l prolly get a totally diff. set of values...
Edited by Ricky2772, 22 October 2003 - 03:09 PM.
Posted 22 October 2003 - 03:53 PM
Posted 23 October 2003 - 07:47 AM
Posted 23 October 2003 - 09:33 PM
Posted 24 October 2003 - 08:17 AM
machine the one that has some thread-less thickness to spare...I think I will machine the arm thingy, not the hub surface. Is this how the lizzie people do it, Ricky?
Posted 24 October 2003 - 08:30 AM
Edited by cheeky_chops, 24 October 2003 - 08:32 AM.
Posted 24 October 2003 - 08:38 AM
Yeah! Correct, cheeky! Also, you can see my progressive Eibach spring in the picture. I think the shims are ca 0,5 mm thick, each giving approx 0,5° reduction of camber (more negative).a shim is a flat 1-2mm thick piece of metal with a hole at either end. This then goes accross the gap pushing the top of the suspension arm out??? less shims mean the wheels are like this /-\ ...... or more shims I-I
Your problem is the abs wire is held in place by what is effectively a shim....??
But I will do what Ricky suggests, machine the arm surface a mm or 2.
Posted 24 October 2003 - 08:58 AM
to be anal,. I think the shims are ca 0,5 mm thick, each giving approx 0,5° reduction of camber (more negative).
Posted 24 October 2003 - 09:12 AM
Posted 24 October 2003 - 09:39 AM
Posted 24 October 2003 - 10:01 AM
1mm thick.
Posted 24 October 2003 - 10:05 AM
Posted 24 October 2003 - 10:59 AM
OOOPS! Important advice! Suppose this is even more imortant if i go for high-gripping Yokosbtw, I replaced the 2 bolts holding the hub and shims in place with stonger ones, rated 12.0, instead of the stock 8.0 ones...having experienced the sudden breakdown on one of them while at 120kmh, it was not fun....
....so I decided to upgrade to a stronger alloy... now I feel better when pushing hard...
Posted 08 March 2004 - 10:18 PM
