VX220 Owners Club: Heater Question - VX220 Owners Club
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Heater Question newbie!
#1 User is offline   maccy.
  • Member
  • Group: Members
Posted 07 February 2010 - 08:02 PM
I picked up my vx yesterday which i'm very happy with thumbsup
however after my 3 hour journey home I was freezing cold!! I dont know if this is a common problem but for some reason my heater knob will only turn about 30 degrees towards both cold and hot!! I've attached a pic and tried to show you about how much I can move it. It does go further with force but springs back. Can anyone advise on what might be wrong. thanks in advance
also should this have a back light?
0
#2 User is offline   Blue Boy
  • Member
  • View gallery
  • Group: Members
Posted 07 February 2010 - 08:06 PM
theres no backlight on these unfortunately, doesnt have that luxury. As far as the movement, open the front bonnet, there is a wire to the left of the silver heater pipe that controls the heater, directly linked to the heater box. check its not jammed, and can freely move.
0
#3 User is offline   Sticky
  • Super Duper Member
  • Group: Members
Posted 07 February 2010 - 08:09 PM
You need to check under the bonnet to see if the cable is fouling anywhere particularly at the heater box end. The paddle that directs the airflow within the heater itself maybe sticking. Also may be worth removing the dash to check the cable.
There is no backlight. Not too many dash lights in the VX and the number reduces with time as the light switches fail.
chinky chinky
PS, Welcome to plastic fun and frollicks
TOOO SLOW AS USUAL
This post has been edited by Sticky: 07 February 2010 - 08:09 PM
0
#4 User is offline   peterg
  • Group: Members
  • Interests:Cars mostly....
Post icon  Posted 07 February 2010 - 08:10 PM
:yeahthat: the control cable/mechanism is probably partly seized :closedeyes:
0
#5 User is offline   techieboy
  • Supercharger of Doom
  • View gallery
  • Group: Members
Posted 07 February 2010 - 08:17 PM
Mine used to do similar and it was the mechanism behind the control panel that was the problem. It looked like the cable outer sheath had come adrift from the clamp that was meant to hold it and then somebody had tried too much force on the knob and it had twisted the mechanism. Took the dash cover off, bent the adjuster arm back to shape and reattached the cable properly and it all worked again.
If you're just after hot air, you can probably just move the arm on the heater box (under the front bonnet) to full hotwarm manually and leave it there for the next few months. It's not like it produces a huge amount of heat anyway.
VX220 SC - Europa Blue, Vocky'd and finally Courtenay'd- before + after dyno chart
0
#6 User is offline   Sticky
  • Group: Members
Posted 07 February 2010 - 08:54 PM
Some have dribbled oil down the cable to lubricate
0
#7 User is offline   simsy
  • Group: Members
  • Interests:Working on sports cars. Motocross bike riding.
    DOB is not real...
Posted 08 February 2010 - 09:06 AM
The 85mm diameter silver air tube can be a real pain (read impossible) to get back on some times. If this pipe is not on correctly then cold air just enters the cabin at speed.
Ensure the heater temp adjuster arm, on the heater box, is all the way to the right hand side of the car. i.e the hot position.
I have just totally rebuilt and sealed my heater box and it is now only OK....
Bleeding chicken McNuggeters, countries full of them!
0
#8 User is offline   maccy.
  • Member
  • Group: Members
Posted 08 February 2010 - 08:51 PM
thanks for your replies.
can anyone piont out where I should be looking to try to sort this out?
thanks
0
#9 User is offline   smiley
  • Super Member
  • Group: Members
Posted 08 February 2010 - 09:54 PM
That big silver hose running from the center to "somewhere down below" is where the heat is coming from.
Down below on top, just next to the silver hose, you will see a small throttle where my text balloons are.
When your heater is set to full warm, that throttle should point away from the cable.
When cold, towards it.
Keep in mind the picture is from a speedster, so your's will be mirrored, but the same rules should apply.
This post has been edited by smiley: 08 February 2010 - 10:27 PM
EP 2-way disks, RS14's, TD's with R1R's and Nitrons/eibachs.
Bmc airbox, ported TB, 2.4 inlet, DBilas outlet manifold, miltek 200 cells cat, janspeed backbox.
Carbon 4-fin diffuser, tubby spoiler, tubby lights.
0
#10 User is offline   Yellow_or_black?
  • Iceman
  • Group: Members
Posted 08 February 2010 - 10:45 PM
Is 'Should the heater controls have a backlight?' the new 'What tyre pressures should I run?'?
0
#11 User is offline   dw1
  • Billy No Mates
  • Group: Members
Posted 08 February 2010 - 10:57 PM
Don't force the heater knob. Go to the bit shown in the photo, use a bit of wd40, a bit of wiggling, bit more of both, bit of patience, do it again a few days later. Do it once more and Bob should be your mothers brother.
Welcome to the world of the vx.
Still lovin' the VX. For the money, I struggle to think of a car that delivers so much performance, tactility and fun.
0
#12 User is offline   Paulus H
  • Super Member
  • Group: Members
  • Interests:I really appreciate my car. I have piled on 55,000 miles in less than 2 years of ownership. I have moved closer to work now - hopefully this will reduce the cost of ownership
Posted 09 February 2010 - 12:11 AM
Welcome. You have bought an awesomely exciting car.
This forum will help you fix any issues you have.
Clearly somewhere along it's path, your heater cable is binding. You find the source, hopefully you'll post the resolution here to help us guys.
Next thing you'll have another question and one of the people from the forum will come up with a fix for you. This is how it works.
Good luck with your car, I've had mine for 45,000 miles and it just gets more exciting the more I get to know it.
Have fun.
#13 User is offline   maccy.
  • Member
  • Group: Members
Posted 09 February 2010 - 10:43 PM
cool, cheers guys Ill have another look in the morning
0
Page 1 of 1
1 User(s) are reading this topic
