What's That Noise... ...again
Posted 08 February 2010 - 11:50 PM
I took it to Guglielmi to have a listen and he didn't seem to concerned and said that a lot of these cars make this noise. Steve’s a top bloke and I don't disbelieve him but wondered if anyone else’s sounds like this? VX paranoia setting in once again.
Anyone recognise it?
Posted 27 February 2010 - 09:00 AM
CHARL13, on 09 February 2010 - 09:26 AM, said:
Could driving it hard with automatic gearbox oil have damaged it?
Posted 27 February 2010 - 02:12 PM
pongle, on 27 February 2010 - 08:52 AM, said:
steve
I had originally thought this but the idea got poo poo'd.
turbobob, on 27 February 2010 - 09:00 AM, said:
Oh dear, at least it has proper oil in it now so it will hopefully lessen any potential further damage. I was planning on trying and remove the gearbox myself and take it to a specialist to overhaul in the summer. With my novice mechanics skills I might have to bite the bullet and pay a garage to do it.
The other possible culprit is one of the shaft bearings. It's funny how it only does it when the car is warm though.
This post has been edited by CHARL13: 27 February 2010 - 02:13 PM
Posted 28 February 2010 - 04:12 AM
CHARL13, on 08 February 2010 - 11:50 PM, said:
Of course (only too happy to help)..that's 'Dave'...
..[/no need to thank me
Please take a look at my petition and add your signature if you agree with it. Thank-You very much.
Posted 28 February 2010 - 11:18 AM
04 VXT
Things Done: 3" Exhaust, Vxr Injectors, Vxr Turbo, Uprated Actuator, Comp Clutch, Light Fly, High flow top hat, Shortbelt mod, HIDs, Mintex M1144, 3 Gauges with bracket, Uprated F+R engine mounts, VW relay, Switches for ABS+Fans, Braided Lines+Dot 5.1
To Do: Chargecooler, Delete Balencer Shafts, Suspension, Geo, TC, Seal Heater box
Posted 28 February 2010 - 05:24 PM
Posted 08 March 2010 - 10:59 PM
CHARL13, on 08 March 2010 - 06:36 PM, said:
Have you tested the clutch release bearing theory earlier in the thread? As this is the most likely source of your noise.
Just try slowly depressing the clutch pedal to see when or if the noise stops/changes.
The pink auto oil in your box is perfectly normal and nothing to worry about.
Vauxhall use it in all their fwd boxes.
Posted 09 March 2010 - 09:58 AM
Mine is 800rpm, but that's irrelevant because it's a turbo
If you are going to get in my car then please observe the rules: don't hit anything when opening the door, don't touch the windscreen surround, don't touch the roof, don't lean on the sill, don't scrape your shoes on anything, don't wear the seat bolster/sill, don't scrape the sill with your trousers, don't pull on the door trim to shut it, don't slam the door, don't lean your right knee on the gear stick, don't rest your right foot where I rest my left foot, don't accidentally kick the bonnet release handle, and don't complain about the rules!
I can has a Facebook?
Posted 10 March 2010 - 10:50 PM
The noise stops at the bite point.
spuk87, on 09 March 2010 - 09:58 AM, said:
No the gear change was fine on the way to the pub so it must have just been the cold. Although if I'd been on the ball I could have asked Andy and Lyndon to have a listen to this noise and see if they recognise it. Andy must have been through his fair share of clutches and gearboxes! I'm going to take it to a transmission specialist this week and get them to have a look. Fingers crossed I won't have to drop my trousers
This post has been edited by CHARL13: 10 March 2010 - 10:51 PM
Posted 11 March 2010 - 09:27 AM
Posted 11 March 2010 - 02:03 PM
Cheers for all the advice guys
Sign In
Register
Help
MultiQuote
