LSJ conversion project
Pics of my LSJ engine conversion project. This is the US spec 2.0LSJ supercharged engine with the US ecu, adapted for the VX220/Speedster.
Other Albums by Exmantaa
988
0
New Z22YH crankshaft (GM 24430375)
2.2 crankshaft + 88mm bore = 2.3L Harrop engine. :-)
Obsolet...
754
0
MAHA dyno Yellow 2.0 LSJ Harrop 80mm
Yellow 2.0 LSJ + Harrop 80mm + 2,5" exhaust on MAHA dyno; 4th gear run
754
0
MAHA dyno 2.0 Harrop 80mm @knock 6100rpm
Same MAHA dyno logplot, showing engine values around 6100rpm, just...
696
0
MAHA dyno 2.0 Harrop 80mm @Max Rpm
HPTuners logplot of the MAHA dyno, showing values around max rpm
984
0
LSJ 2.0 engine with Harrop supercharger on MAHA dyno
- Stock 2.0 LSJ/Saab bottom end (incl. balancer shafts). Light...
823
0
Dyno plots 2.0 vs 2.2 engine. (power @ wheels)
Rpm scale is a bit off here, as my rpm limit was set to ~7200, Smil...
1085
0
IAT log after short burst
IAT2 (=intake T manifold) reaching 42*C after 1 single short burst...
1018
0
Scanning for fault codes 1
Yes, still need to connect the IC pump so that is seen as an error...
1117
0
Scanning the engine for hunting idle 1
The idle was hunting with intermediate stalling, so let's see w...
966
0
First drive after clutch bleed
All oil and waterhoses connected. SC manifold in, together with som...
996
0
First start-up, outside...
1060
0
VXT exhaust fitted and ready to run...
1114
0
Temporary airfilter & MAF tube
1025
0
All connected, temporary layout
1064
0
LSJ Alternator & water tophose
1330
0
Fuel hoses & dual pass connected
931
0
Cleaned panel & new mounts
Needed more space to move the car around, so this one had to move up.
