Javascript Disabled Detected
ABS line filter for Racelogic Traction Control
cs_
, Dec 17 2011 06:59 AM
Copyright
www.lotus116.de
This is the filter to eliminate most of the noise you get an ABS lines if you connect the Racelogic TC to the ABS sensors. Without you will get many random engine cuts below ~40 km/h. With the filter you will encounter no cuts anymore dwon to ~10 km/h. Very important for this result is a well thought connection of the power wires of the TC. Find more details on proper wiring on www.lotus116.de (german language, use google translate + password protected blog, send me a PM for getting access).
File Name
Unix Timestamp
1324105192
Original File Size
131632
File Type
2
Mime Type
image/jpeg
Sections Found
ANY_TAG, IFD0, THUMBNAIL, EXIF, INTEROP
HTML Sizes
width="640" height="480"
Image Height
480
Image Width
640
Color
TRUE
Byte Order Motorola
FALSE
COMPUTED.CCDWidth
1mm
Aperture F-Number
f/3.5
COMPUTED.FocusDistance
0.55m
COMPUTED.UserCommentEncoding
UNDEFINED
Thumbnail File Type
2
Thumbnail Mime Type
image/jpeg
IFD0.ImageWidth
4000
IFD0.ImageLength
3000
IFD0.PhotometricInterpretation
2
Camera Make
Canon
Camera Model
Canon PowerShot G9
Orientation
The 0th row is at the visual top of the image, and the 0th column is the visual left-hand side
IFD0.SamplesPerPixel
3
X-Resolution
1800000/10000
Y-Resolution
1800000/10000
Resolution Unit
2
Software
Adobe Photoshop CS5 Windows
Date Taken
2011:03:18 17:26:16
Artist
CarstenSeehawer
YCbCr Positioning
centered
Thumbnail Compression
JPEG Compression
Thumbnail X-Resolution
72/1
Thumbnail Y-Resolution
72/1
Thumbnail Resolution Unit
2
Thumbnail JPEG Interchange Format
1262
Thumbnail JPEG Interchange Format Length
5872
Exposure Time
1/60
F Number
35/10
ISO Speed Ratings
80
Exif Version
0220
Date Digitized
2011:03:18 17:26:16
Compressed bits/pixel
5/1
EXIF.ShutterSpeedValue
189/32
EXIF.ApertureValue
116/32
Exposure Bias Value
0/3
Max Aperture Value
116/32
EXIF.SubjectDistance
55/100
Metering Mode
Pattern
Flash
89
Focal Length
16822/1000
Flash Pix Version
Flashpix Format Version 1.0
Color Space
sRGB
Image Length
480
Interoperability Offset
1112
EXIF.FocalPlaneXResolution
4000000/291
EXIF.FocalPlaneYResolution
3000000/219
EXIF.FocalPlaneResolutionUnit
2
Sensing Method
One-chip color area sensor
EXIF.CustomRendered
0
Exposure Mode
Auto exposure
White Balance
Auto white balance
EXIF.DigitalZoomRatio
4000/4000
Scene Capture Type
Standard
Inter-operability Index
R98
Inter-operability Version
0100
INTEROP.RelatedImageWidth
4000
INTEROP.RelatedImageHeight
3000
1#090
%G
IPTC.By-line
CarstenSeehawer
IPTC.DateCreated
20110318
IPTC.TimeCreated
172616+0000
VX220 Owners Club
→ Gallery
→ Member Albums
→ My Speedster VX5 EVO
→ ABS line filter for Racelogic Traction Control
