Javascript Disabled Detected
Engine build-up 2012: Tullett bespoke downpipe
cs_
, Feb 11 2012 06:33 AM
Copyright
www.lotus116.de
This is a special bespoke 3" downpipe, built 10mm higher at the turbo flange, with an additional bung for wideband lambda.
It's been coated with high temperature ceramics by a german specialist company which gives the titan look. Coating can handle temperatures up to 1.100 deg celsius and reduces heat emissions from the exhaust. Will take care for some additional HP if all goes as if expected.
File Name
Unix Timestamp
1328942002
Original File Size
59323
File Type
2
Mime Type
image/jpeg
Sections Found
ANY_TAG, IFD0, THUMBNAIL, EXIF
HTML Sizes
width="320" height="394"
Image Height
394
Image Width
320
Color
TRUE
Byte Order Motorola
TRUE
Thumbnail File Type
2
Thumbnail Mime Type
image/jpeg
Orientation
The 0th row is at the visual top of the image, and the 0th column is the visual left-hand side
X-Resolution
720000/10000
Y-Resolution
720000/10000
Resolution Unit
2
Software
Adobe Photoshop CS5 Windows
Date Taken
2012:02:09 10:14:44
Thumbnail Compression
JPEG Compression
Thumbnail X-Resolution
72/1
Thumbnail Y-Resolution
72/1
Thumbnail Resolution Unit
2
Thumbnail JPEG Interchange Format
302
Thumbnail JPEG Interchange Format Length
7843
Color Space
sRGB
Image Length
394
VX220 Owners Club
→ Gallery
→ Member Albums
→ My Speedster VX5 EVO
→ Engine build-up 2012: Tullett bespoke downpipe
