Javascript Disabled Detected
Engine build-up 2012: Uwe Regelins estimation of Power
cs_
, Mar 25 2012 09:39 AM
Copyright
www.lotus116.de
Uwe wrote down a number secretly before going on the dyno. He told me he will show it to me afterwards. 395 was his estimation of what my engine will output finally. At the end of day 1 (not ready yet) we had 388PS (~HP). Not so bad...
And the engine is running so smoothly as the old one, while normal driving you hear no difference. Only idle RPM had to be set a bit higher.
File Name
Unix Timestamp
1332668364
Original File Size
42842
File Type
2
Mime Type
image/jpeg
Sections Found
ANY_TAG, IFD0, THUMBNAIL, EXIF, INTEROP
HTML Sizes
width="480" height="360"
Image Height
360
Image Width
480
Color
TRUE
Byte Order Motorola
FALSE
COMPUTED.CCDWidth
0mm
Aperture F-Number
f/3.2
COMPUTED.FocusDistance
0.34m
COMPUTED.UserCommentEncoding
UNDEFINED
Thumbnail File Type
2
Thumbnail Mime Type
image/jpeg
IFD0.ImageWidth
4000
IFD0.ImageLength
3000
IFD0.PhotometricInterpretation
2
Camera Make
Canon
Camera Model
Canon PowerShot G9
Orientation
The 0th row is at the visual top of the image, and the 0th column is the visual left-hand side
IFD0.SamplesPerPixel
3
X-Resolution
1800000/10000
Y-Resolution
1800000/10000
Resolution Unit
2
Software
Adobe Photoshop CS5 Windows
Date Taken
2012:03:23 18:50:38
Artist
CarstenSeehawer
YCbCr Positioning
centered
Thumbnail Compression
JPEG Compression
Thumbnail X-Resolution
72/1
Thumbnail Y-Resolution
72/1
Thumbnail Resolution Unit
2
Thumbnail JPEG Interchange Format
1262
Thumbnail JPEG Interchange Format Length
4033
Exposure Time
1/60
F Number
32/10
ISO Speed Ratings
200
Exif Version
0220
Date Digitized
2012:03:23 18:50:38
Compressed bits/pixel
5/1
EXIF.ShutterSpeedValue
189/32
EXIF.ApertureValue
107/32
Exposure Bias Value
0/3
Max Aperture Value
107/32
EXIF.SubjectDistance
34/100
Metering Mode
Pattern
Flash
24
Focal Length
12733/1000
Flash Pix Version
Flashpix Format Version 1.0
Color Space
sRGB
Image Length
360
Interoperability Offset
1112
EXIF.FocalPlaneXResolution
4000000/291
EXIF.FocalPlaneYResolution
3000000/219
EXIF.FocalPlaneResolutionUnit
2
Sensing Method
One-chip color area sensor
EXIF.CustomRendered
0
Exposure Mode
Auto exposure
White Balance
Auto white balance
EXIF.DigitalZoomRatio
4000/4000
Scene Capture Type
Standard
Inter-operability Index
R98
Inter-operability Version
0100
INTEROP.RelatedImageWidth
4000
INTEROP.RelatedImageHeight
3000
1#090
%G
IPTC.By-line
CarstenSeehawer
IPTC.DateCreated
20120323
IPTC.TimeCreated
185038+0000
VX220 Owners Club
→ Gallery
→ Member Albums
→ My Speedster VX5 EVO
→ Engine build-up 2012: Uwe Regelins estimation of Power
