Javascript Disabled Detected
Line Filter Racelogic Traction Control to VX220/Lotus-ABS
cs_
, Oct 19 2013 09:14 AM
Copyright
www.lotus116.de
These are the original filter units, developed and produced by www.lotus116.de
They are necessary in Lotus cars to get rid of signal disturbances and unwanted engine hickups at low speeds from misinterpretations of the ABS Sensor Signals. Also the ABS does not drop any errors anymore.
COMPUTED.CCDWidth
1mm
COMPUTED.UserCommentEncoding
UNDEFINED
EXIF.ShutterSpeedValue
189/32
EXIF.ApertureValue
95/32
EXIF.FocalPlaneXResolution
4000000/291
EXIF.FocalPlaneYResolution
3000000/219
EXIF.FocalPlaneResolutionUnit
2
EXIF.CustomRendered
0
EXIF.DigitalZoomRatio
4000/4000
INTEROP.RelatedImageWidth
4000
INTEROP.RelatedImageHeight
3000
MAKERNOTE.ImageType
IMG:PowerShot G9 JPEG
MAKERNOTE.FirmwareVersion
Firmware Version 1.00
MAKERNOTE.ImageNumber
1007289
MAKERNOTE.OwnerName
CarstenSeehawer
File Name
Unix Timestamp
1382174099
Original File Size
390237
File Type
2
Mime Type
image/jpeg
Sections Found
ANY_TAG, IFD0, THUMBNAIL, EXIF, INTEROP, MAKERNOTE
HTML Sizes
width="800" height="800"
Image Height
800
Image Width
800
Color
TRUE
Byte Order Motorola
FALSE
Aperture F-Number
f/2.8
Thumbnail File Type
2
Thumbnail Mime Type
image/jpeg
Camera Make
Canon
Camera Model
Canon PowerShot G9
Orientation
The 0th row is at the visual top of the image, and the 0th column is the visual left-hand side
X-Resolution
180/1
Y-Resolution
180/1
Resolution Unit
2
Date Taken
2011:11:15 11:25:35
YCbCr Positioning
centered
Thumbnail Compression
JPEG Compression
Thumbnail X-Resolution
180/1
Thumbnail Y-Resolution
180/1
Thumbnail Resolution Unit
2
Thumbnail JPEG Interchange Format
5108
Thumbnail JPEG Interchange Format Length
5028
Exposure Time
1/60
F Number
28/10
ISO Speed Ratings
200
Exif Version
0220
Date Digitized
2011:11:15 11:25:35
Compressed bits/pixel
5/1
Exposure Bias Value
0/3
Max Aperture Value
95/32
Metering Mode
Pattern
Flash
89
Focal Length
9855/1000
Flash Pix Version
Flashpix Format Version 1.0
Color Space
sRGB
Image Length
800
Interoperability Offset
3362
Sensing Method
One-chip color area sensor
Exposure Mode
Auto exposure
White Balance
Auto white balance
Scene Capture Type
Standard
Inter-operability Index
R98
Inter-operability Version
0100
VX220 Owners Club
→ Gallery
→ Member Albums
→ thread_cache_cs
→ Line Filter Racelogic Traction Control to VX220/Lotus-ABS
