Changing the Alarm LED
Posted 16 October 2006 - 08:36 PM
Posted 16 October 2006 - 10:43 PM
Posted 26 October 2006 - 10:44 PM
Posted 27 October 2006 - 08:32 AM
Well I finally got round to taking the LED out, and sure enough, one of the legs is broken off. Now I just need to know what to replace it with.
Meldert says he replaced his with a regular 2.1V 10ma LED, but someone else said it was a 12V LED. Assuming both work, I can't see a 12V LED working if it was being supplied with 2,1V but I guess a 2,1V LED might work for a while with 12V. So if nobody can give a definitive answer, I'll go for the 12V one.
I'll be damned if I'm going to buy one from Opel - and I'm still waiting for the oil filter O-ring that I ordered 3 or 4 weeks ago.
[geekiness]
In geek speak the 2.1V refers to the forward drop of the LED and is dependent on the material it is made from. You need to add a resistor (in series) to get the correct operating current. It's been a while since I last did this but IRC you work it out by doing (Vs-Vf)/I = (12-2.1)/10E-3 = 990Ohms. You need to then ensure the resistor can sink enough power = (i^2)R so in this case about 1/10 W so just make sure you get a resistor rated above this (1/4 or 1/3 watt is very small and common so will be fine). If you want it brighter, increase the current (ie reduce the resistor - value but be aware this may reduce the life of the LED and may require a beefier resistor (do the power calculation))
[/geekiness]
Edited by stuarth1, 27 October 2006 - 08:36 AM.
Posted 27 October 2006 - 04:05 PM
Posted 27 October 2006 - 05:15 PM
Posted 02 January 2007 - 09:29 PM
A 12v 5mm led will work fine Changed mine a while back and it works prefectly
Agreed.
I couldn't find one over here, but got exactly what I was looking for in Maplins - a 5mm "Super bright" 12v red LED. Here's what the spec. says:
"Order Code CJ63T: Super Bright Red
Kingbright description: L-53SRD-12V
Forward current typ.: 8.5mA
Forward voltage max.: 14V
Reverse voltage max.: 5V
Wavelength @ peak : 660nm
Power dissipation PT: 120mW
Light output min.@ 12V: 100mcd
Light output typ.@ 12V: 180mcd
5mm 12V LEDs FAQs:
Q) What is the difference between sb and he leds - kathryn gibson
A) Super Bright (sb) is 180mcd light output and High Efficiency (he) is 30mcd light output.
Q) can i get the 12V 5mm LED in blue - Jody
A) Only available in red,green and yellow."
I've only tested it for a few blinks, but I'm sure it'll work fine, and as it's "Super Bright" maybe it'll be easier to see in the daylight!
Hope this helps the next person.
Posted 02 January 2007 - 09:41 PM
Posted 02 January 2007 - 11:02 PM
Posted 03 January 2007 - 12:34 AM
Posted 03 January 2007 - 07:45 AM
Posted 17 January 2007 - 07:20 PM
Posted 17 January 2007 - 07:24 PM
Posted 17 January 2007 - 07:34 PM
you dont need a flashing led.... if you fit one then the flashing led will flash then stop flashing with the pulses from the alarm ecu.
That makes sense. Many thanks.
Posted 14 November 2010 - 04:50 PM
Edited by Hang-em, 14 November 2010 - 04:52 PM.
Posted 09 April 2011 - 12:13 PM
Posted 09 April 2011 - 12:23 PM
I assume it should be flashing or is the VX alarm light just a steady LED light?
My alarm LED flashes.
And I also have ANOTHER bright red flashing LED in an attempt to give my VX a "Do not touch" deterrent when parking in London.
Posted 18 November 2013 - 05:20 PM
Just fitted a new LED for my alarm with the correct META one, you can get then here http://abacuscaralar...21be498f7386a0c
Mick
