follow instructions
So here is a idiots guide to removing the door panel and window winder for anyone who
is planning to remove their door cards or adjusting the windows.
If I'm covering old ground then please feel free to
Part 1
First remove the screw on the side.
Then carefully pull off this part which is attached by three plastic clips in the area arrowed,
just remember these panels are made from hard foam and can break easily so do not
force it off.
Then remove the three plastic clips to re-use when re-fitting.
Next remove the screw from the next panel.
Then remove the four allen key bolts from the window winder
Next remove the allen key bolt from the centre
You can now start to remove the large panel from the several plastic clips that hold it
to the door, start from the back and work forward without breaking the foam panel.
You will need to get behind the panel and pull out the two plastic screws that hold the handle guard in place.
Part 2
Carefully remove the door panel around the door guard.
Next twist off the handle guard.
The door cards are held in place by six plastic clips as shown, but remember these door
cards can crack really easy if forced off.
If nothing has broken you should be left with these pieces.
I have decided to cover the door cards at a later date and i have put the black panels back on
so i can still use the car, I am also planning to stick the door cards back on with Velcro and
not re-using the six plastic clips.
As far as adjusting the windows I'll leave that to someone else to explain
