surly thats helping you get round the corner? if it was to stiff, surly it would give you more understeer? atleast thats what i thought
Body roll only has a relationship to understeer if the front compression is stiffer than the rear.
i see, so providing you have an even compression on front and rear, or more compression at the rear, your OK ?
Erm....<hooo!>
this is a massive topic! people have written books on this stuff
What I have learned so far about the VX is, as far as
Compression is concerned (ie: how quickly the damper firms up when you lean on it (whether over a bump or compressing into a corner) you need to keep the balance of compression stiffness from front to rear as close as you can.
To improve turn-in, you can soften up the front compression but, only to a point. As the more you do this, the more you start to compromise overall grip.
I've found I've had to completely change my driving style (massively for the better btw) to overcome what_I_originally_felt_was_understeer and, have gone from a soft front-end to a much harder setting (more in-line with the rear) and as a result, I can carry more corner entry speed, as the front of the car can be loaded up more on turn-in without stepping out (as it used to do when the rear was harder than the front).
What felt clear over this kerb (pictured) was my rebound is a little too hard still, as the car didn't recover well from each bump, it skipped across the tarmac after mullering the kerb; i've still some work to do on the rebound.
My concern from the above picture was body-roll: I never thought the VX would roll that much. Maybe it's a small optical illusion, as the shot in this pic (from a different day) shows much less pronounced roll.....
Edited by Stu-7, 20 February 2007 - 04:21 AM.
