E12 & E14 Torx sockets
8mm regular socket
5mm hex bit (or Allen key)
Ratchet & Extension bars
Small flat head driver
A Trolley jack
A pair of wheel ramps
The revised idler bracket #93183526
A new poly V belt
Start by jacking up the rear of the car at the designated jacking points and supporting the wheels with the ramps (you can reverse the car onto them but it’s not as easy as it sounds).
Next remove the middle under tray by unscrewing the 5 M5 bolts that connect it to the rear under tray using the 8mm socket. Remove the 6 M5 bolts (3 on each side) of the middle tray. Finally take out the two M8 bolts in the centre using the 5mm hex bit. Take the tray off and move it out of the way for now.
Underneath the car with the tray off you can now see the v belt assembly on the driver’s side of the engine.
It is looped around four wheels, from the bottom clockwise; drive wheel, alternator, tensioner pulley and the ac idler pulley. The ac idler pulley sits on the end of the idler bracket.
The bracket is attached to the block by three Torx bolts. Use the E12 socket to unscrew the two bolts closest to the idler wheel first (#1 shown in photo above, the other is behind the pole attached to the wheel) and then finally the one furthest away (Rear bolt is just visible in background of photo). Now the bracket is free of the block, unthread the v belt and remove the bracket assembly from the engine bay (this can be a bit tricky because of the limited space).
Remove the old v belt and replace it with the new one, threading it around the wheels the same way as the old one.
With the bracket removed, use a small flat head screwdriver to pop off the black cap on the end of the wheel. Use the E14 Torx socket to unbolt the wheel from the bracket.
As you can see by the picture the old and revised brackets are very similar but the new one is slightly larger. Bolt the wheel onto the new bracket and put it back into the engine bay (leave off the cap for now).
Refitting the bracket is the hard part as the belt is very tight and only stretches a little. The easiest way I found to re-fit is to attach the E14 Torx socket to a small extension bar (about 2â€) and fit it onto the bolt that secures the idler wheel to the bracket, place the bracket so it touches the bottom of the tensioner wheel and thread on the v belt. With one hand on the socket and extension and the other holding the bracket push upwards until the bracket is in position. Loose bolt the front two E12’s with your hand then slowly tighten them up evenly with the ratchet, this will bring the bracket in line for the furthest away bolt. Screw in the last bolt and tighten them all to secure the bracket.
That’s it now refit the cap on the end of the idler wheel and refit the under tray.
