Front End Seems Light After New Tyres
13 replies to this topic
#1 crsnwby
crsnwby
  • 510 posts
Posted 02 April 2007 - 01:53 PM
Hi.. just a quick one.. I had my rears replaced with new Potenza Lotus fitment RE040's but since then when im driving rather fast the front seems light and the car seems to sway round fast long corners... Whats that about? Is it the pressures too high?
#2 robfenn
robfenn
  • 1,955 posts
  • Interests:Sports, Photography, Travelling, Racing Cars.
Posted 02 April 2007 - 02:22 PM
Have you checked the pressures then? Fitters normally get them way wrong! Remember they need bedding in too :)
#3 jasvxt
jasvxt
    Scary
  • 4,527 posts
Posted 02 April 2007 - 02:35 PM
Check pressures i use 24psi front and 26 psi rear and so do lots of other people of here thumbsup HTH Jas
#4 VIX
VIX
  • 9,497 posts
Posted 02 April 2007 - 02:38 PM
1. Are you sure they are the correct tyres for the VX220 and are matched to the fronts? IIRC RE040's are also made for Audis and are too soft. Loads of info on this site about finding and identifying the correct tyres. 2. Are the tyre pressures correct? Fitters normally over-inflate to get the tyre bead seated. 3. Are the wheel nuts correctly torqued ? Hopefully they are not loose? chinky chinky
#5 crsnwby
crsnwby
  • 510 posts
Posted 02 April 2007 - 02:56 PM
Cheers there RE040's Lotus Fitment ones. He torqued the nuts up correctly and pressured them to 30Psi so i think they maybe over inflated a bit... What should they be?
#6 NickH
NickH
  • 2,171 posts
Posted 02 April 2007 - 03:16 PM
I'm running 24 front, 26 rear.
Plus as already said they will need to be bedded in for a few miles thumbsup
#7 caleebra
caleebra
  • 4,479 posts
Posted 02 April 2007 - 03:27 PM
30 is way too high... the manual states 26.5 I think and you'll notice a huge difference between the two, as you would going down to 24. It's a personal preference thing but 30 is definitely too hard!!
#8 LazyDonkey
LazyDonkey
    Lotus imposter
  • 7,748 posts
Posted 02 April 2007 - 04:05 PM
Lotus fitment does not necessarily mean they are the right one.
They need to be RE040BZ 225/45 R17 - 90W
Most tyre shops will try and give you TT tyres which may have a higher speed rating but not the right loading* (eg. 91Y) If you have the "wrong" tyres it's not the end of the world - just a bit annoying when you shell out £120 notes each. In saying that tyre pressures make a HUGE difference so that's probably the probelm.
* well it's loading or weight rating or something. :lol:
#9 wil_scotland
wil_scotland
  • 646 posts
  • Interests:Footy, cars, drinking. Just the usual!
Posted 02 April 2007 - 04:12 PM
I also run 24 at the front and 26 for the rears thumbsup rallly
#10 crsnwby
crsnwby
  • 510 posts
Posted 02 April 2007 - 04:14 PM
There 225 45 17 W ones. They were made for the lotus elise to give a smoother ride so i assume there the correct ones. I will pop out now and let the tryes down :blink:
#11 Pidgeon
Pidgeon
  • 5,254 posts
Posted 02 April 2007 - 04:55 PM
You have the wrong tyres fitted, see garyk's post here
#12 VIX
VIX
  • 9,497 posts
Posted 02 April 2007 - 05:01 PM
The correct spec is:
Fronts - RE040BZ 175/55 R17 - 81W DOT CAD (DOT CFE/ DOT CJC is old stock...)
Rears - RE040BZ 225/45 R17 - 90W DOT CFE (DOT CJC is old stock)
I have no idea what the stuff about a smoother ride for Elises is about. AFAIK the correct tyre is made specifically for the VX220. Remember Elises are almost certainly a different weight to the VX. Are your's the correct DOT code? Loads of info here.
Edit: Didn't see Partridge's post above. thumbsup
Edited by VIX, 02 April 2007 - 05:42 PM.
#13 crsnwby
crsnwby
  • 510 posts
Posted 03 April 2007 - 12:45 PM
had a look this am and there DOT EJH8 CFE
#14 stubbow
stubbow
  • 54 posts
Posted 03 April 2007 - 01:06 PM
CFE is the correct dot code Let them down to 26psi and give them 100 miles or so to bed in. While your at it check the front pressures i run mine at 24psi All pressures should be set when tyre is cold with a decent gauge and not the local garage air line that will be way out! Danny
