Guide To Changing EGR Valve
2 replies to this topic
#1 n1k_ns
n1k_ns
  • 2,127 posts
  • Interests:Date Of VX First Registration: 01/03/2002
Posted 19 June 2007 - 08:30 PM
Hi,
My VX developed a problem afew weeks ago where as when it was idling (traffic lights etc) or going below 15mph the revs were constantly fluctuating casuing lack of power and very bad fuel consumption. see the video below:
Idling Video
The car felt like it was going to stall at any minute and trying to start the engine turned into a nightmare. I initially thought it may be the spark plugs, so i changed them with brand new ones, only to find it had not changed at all :( After about an hour of driving, the engine warning light came on so i took it to a specialist and it was diagnosed as a Faulty EGR Valve. A replacement valve from Vauxhall is approx £130. I had a bit of a reaserch and vocky told me that the EGR valve is actually not required, and he was selling an EGR cheater to completley replace the whole valve for around £10. I would have done this but i needed to get it up and running asap.
After spending 2 days searching the scrapyards, i came across a 2001 Vauxhall Vectra so i took the valve off that. (it is also the same from the 2.2 Astra and Zafira) Just make sure its from a Z22SE engine! Mine was £24 thumbsup
Here is a basic guide on how to replace it:
First undo the two bolts either side of the valve (one side shown here):
Then remove the plug from the top (There is a small plastic 'catch' on the inside of the black plug at the top):
Then the old one is out, the gasket underneath can be re-used for the next one:
Here is the EGR valve and gasket:
Then once you have the replacement valve, just do the reverse! thumbsup
10 mins max!
#2 SamVx
SamVx
  • 736 posts
Posted 20 June 2007 - 07:53 AM
Good work! Imnotworthy
#3 n1k_ns
n1k_ns
  • 2,127 posts
Posted 20 June 2007 - 07:58 AM
Cheers :D How come you are on so early? Where do you work?
