Bought A Set Of These Bad Boys on Ebay (£50 inc P&P)
ALPINE SPS-170A TYPE S 6.5" CAR COAXIAL SPEAKERS
I obviously started with the Drivers side as you can slide the seat forward and it is very easy.
First, using the flat blade screwdriver attachment on my leatherman I removed the grills to get access to the screws:
Once thats off, just remove the 4 phillips screws. (Note how crappy the speakers are compared to the Alpine ones):
Then remove the retaining ring:
The speaker should then just drop out:
Then simply remove the terminals from the speaker, re-attach to the new one and offer up the new one. (mine had to go in at a slight angle to line up the holes):
Then attach the new speker grills and screw them back in....Job Done:
The left side was much harder and took twice as long due to the small area to work with, but again i found the leatherman fit perfectly
Old Paper Phillips Speakers:
The sound was noticably much better from the word go, i also have an Alpine H/U and this is one of the best mods i have done so far!
