Think My Stater Motor Is Broken
Posted 09 November 2009 - 08:05 PM
Posted 09 November 2009 - 08:15 PM
Posted 09 November 2009 - 08:20 PM
Thanks will try . but they checked earth and supplySome people have had trouble with their ground strap. Try putting a jumper cable from the engine to the chassis.
Posted 09 November 2009 - 08:24 PM
No good 'checking' the grounds, unless you see good voltage across the starter while it is cranking. Dodgy grounds test fine until you start putting cranking amps through them.Thanks will try . but they checked earth and supplySome people have had trouble with their ground strap. Try putting a jumper cable from the engine to the chassis.
Posted 09 November 2009 - 08:25 PM
Posted 10 November 2009 - 04:37 PM
Yes that's wot its doing. Had starter motor of to day it looks and smells burnt out . plus iv snapped a bolt of which holds a wire on . Ordered one of eBay. Hope it comes soon ! stuck a home till i fix it . good job there's not much work at the momentIs the starter turning the engine over then but just slowly?
Posted 11 November 2009 - 11:34 AM
New part has come it wrong p**d ofYes that's wot its doing. Had starter motor of to day it looks and smells burnt out . plus iv snapped a bolt of which holds a wire on . Ordered one of eBay. Hope it comes soon ! stuck a home till i fix it . good job there's not much work at the momentIs the starter turning the engine over then but just slowly?
Posted 11 November 2009 - 03:27 PM
Posted 11 November 2009 - 03:28 PM
Posted 11 November 2009 - 03:33 PM
ANY ONE KNOW THE PART NUMBER 10 DIGIT ???
Posted 11 November 2009 - 03:45 PM
