Vauxhall Dealer Offering Us A Discount
475 replies to this topic
#181 PaulCP
PaulCP
  • 6,066 posts
Posted 08 May 2011 - 06:13 PM
Could you give a price for the cap and bottom section (i believe they come as one) for the oil filter housing on an NA. Also availability
chinky chinky
Bump ready for your return to the grindstone!
Edited by PaulCP, 08 May 2011 - 06:20 PM.
#182 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 09 May 2011 - 09:03 AM
cambelt kit , since most turbos will now need there second change this year
LET = no kit specified
LEH = kit = PN 93185844 - £66.40+VAT (Retail £85+VAT)
Belt = 55351782 - £15.20+VAT (Retail £22+VAT)
Tensioner = 55353810 - £21.20+VAT (Retail £21.20+VAT)
Roller (Exhaust) = 55353701 - £12.60 (Retail £14.45+VAT)
Roller (Inlet) = 90529810 - £12.+VAT (Retail £14.45+VAT)
Water pump = 24409355 - £48.40+VAT (Retail £62+VAT)
SCREW,HEX.HD.,M12,WHEEL TO HUB = 9197978 ( quantity four to replace security wheel bolts) - £2.20+VAT each (Retail £2.92+VAT)
#183 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 09 May 2011 - 09:07 AM
N/A tie rods back in stock.
Got my set but the threads are different to the original ones so need new nuts.
Apologies about that Cliffie and that's rather cheeky of them.
Only ones listed on EPC are M10 and M12 although no-one seems to want to give me a price for M12's so I'd hazard a guess that that's the problem you're experiencing?
M10 - 93178113 - £9.60+VAT each (Retail £11.35+VAT each)
#184 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 09 May 2011 - 09:11 AM
chinky chinky
Have a look at this screenshot of EPC just to make sure.
#185 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 09 May 2011 - 09:15 AM
After a recent track day the cheapo water pump I put on my Z22se 2.2 about a year ago is making some bearing noise. Posted Image
How much for the real deal with new seals Mr AstonVauxhall? Posted Image
Buy once, buy well. Lesson learnt.
Well, I've still not forgiven you for what you did to my friends, Scott, Alan, Virgil et al, but this time, I'll let you off, but only because I'm nice.
N/A Water Pump - 12630084 - £55+VAT (Retail £69.50+VAT) Posted Image
#186 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 09 May 2011 - 09:19 AM
chinky chinky
Posted Image thanks for the bump dude.
I'm scampering through my PM's, so to anyone who hasn't had a reply yet, I will get back to you as soon as I can.
On a side note, I'm not in tomorrow (funeral unfortunately) and I'm not in Wednesday (meeting in Kent so an all day job). But other than that, I can't foresee any more holiday for a while.
No Le Mans for me this year (end of a 5 year streak Posted Image), so theoretically for the rest of the year, we're good to go!
#187 siztenboots
Posted 09 May 2011 - 09:21 AM
fantastic , thanks for that thumbsup
#188 techieboy
Posted 09 May 2011 - 09:28 AM
Here's an obscure one for you James. How about a price on these 9197176 - PLUG,RUBBER,WITH FIXING PIN Cheers. chinky chinky
#189 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 09 May 2011 - 09:32 AM
That's an easy one!
9197176 - PLUG,RUBBER,WITH FIXING PIN - £1.10+VAT (Retail £1.39+VAT) Posted Image
#190 techieboy
Posted 09 May 2011 - 09:39 AM
thumbsup
#191 PaulCP
PaulCP
  • 6,066 posts
Posted 09 May 2011 - 10:38 AM
chinky chinky
Yep number 12 which i understand comes with number 11 so part numbers 9198199 and 9198190
I,ve been told they are special order only and no delivery date would be given, probably due to needing sufficient orders for a production run
If the price is attractive enough maybe others will buy as spares given the nightmare these parts cause
Paul
#192 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 09 May 2011 - 11:30 AM
Paul
With all the trouble I had/have I would think that most of us, who wanted to replace these parts would also require part 13 as well 9198175
EDIT: to add part number.
Edited by Mangham54, 09 May 2011 - 11:31 AM.
#193 ElizP987
ElizP987
  • 4,037 posts
Posted 09 May 2011 - 12:34 PM
chinky chinky
Paul
If you stuggle and want some used ones, give me a shout
#194 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 09 May 2011 - 12:36 PM
Paul
Ok then.
9198199 - £40.06+VAT
9198190 - £30.80+VAT
9198175 - £87.40+VAT
#195 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 09 May 2011 - 12:41 PM
Sorry, I think you misunderstood me.
The pitch of the thread is different to standard therefore the tie rods are not a direct OE swap. You should price up and supply new nuts with them on that basis.
#196 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 09 May 2011 - 12:51 PM
That's really odd? Apologies for the confusion.
I genuinely never had any idea that tie rods were modified in any way (EPC shows nothing of the sort). EPC lists one part number for N/A tie rods, and it's never changed/been superseded/modified). And when any part is modified etc, the part number changes.
What's the pitch of the ones I sent you? Vs. the ones that were on your car. Is it drastically out?
And I've no complaints from others who've ordered them but if anyone has fitted some N/A tie rods that they got from me, Cliffie and I would be interested to hear your findings/experiences when fitting.
#197 PaulCP
PaulCP
  • 6,066 posts
Posted 09 May 2011 - 02:01 PM
Paul
Ok then.
Availability?
#198 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 09 May 2011 - 04:52 PM
Actually Cliffie, don't worry about it. PM your number and I'll give you a tinkle when I'm back in on Thursday and I'll get you sorted Posted Image
#199 AMOSS
AMOSS
  • 542 posts
Posted 09 May 2011 - 05:13 PM
Hi, Can you give me a price for the camber shims between the Hub and the carriers for the ABS for the front and the back please. The part numbers are: 9197822 x2 9197837 x2 (NLS.- USE 9197850) Whatever this means.. Cheers Andy
#200 jbudgie
jbudgie
  • 521 posts
Posted 09 May 2011 - 07:33 PM
Sorry if this is a daft question, but why is there no kit for the LET specified?
