Vauxhall Dealer Offering Us A Discount
475 replies to this topic
#401 Muncher
Muncher
  • 4,494 posts
Posted 17 July 2011 - 02:38 PM
Thanks James, everything arrived with vocky. Imnotworthy Very, very good customer service. It's especially refreshing to actually get prompt emails back and a call to say things had been dispatched, something AutoVaux never really managed.
#402 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 18 July 2011 - 07:44 AM
No problem chap, anytime Posted Image
#403 CJones
CJones
  • 109 posts
Posted 18 July 2011 - 08:34 AM
Morning. Need to order a few bits from you. I require; 1. Service book 2. Driver headrest surround 3. Front Splitter clips Can you let me know costs and i can sort with you today. Thanks Chris
#404 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 18 July 2011 - 09:01 AM
Morning.
I require;
1. Service book
Thanks
Chris
No problem Chris Posted Image
Service book - £18 incl.VAT (I'll need a photocopy of your V5 for this one, it's just easier. It has reg, chassis number, your name and address etc)
Driver headrest surround - Do you mean the 'pad'? I think it's 9197908 - £67+VAT (Retail £87+VAT)
Front Splitter clips - They're actually rivets on EPC - which are 81p+VAT each (Retail £1.02+VAT each), and EPC tells me you'll need 6 of them.
#405 jbudgie
jbudgie
  • 521 posts
Posted 28 July 2011 - 02:41 PM
Hi, whats the price for a F23 gearbox (tubby). Do you do reconditioned ones ? Or a full set of internals ?
#406 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 28 July 2011 - 03:01 PM
Outright, they're £2,270.11+VAT (Retail £2,521+VAT)
Exchange - I can't seem to find a price, but I'd budget on it being slightly cheaper, but not by much.
We don't do reconditioned units, just Vauxhall stuff.
Do you need a full full list of internals?
#407 sford
sford
  • 1,452 posts
Can I have a price on these two items please:-
STONE PROTECTION
1 STONE PROTECTOR,SIDE PANEL,RH (FOIL) 1 9197267 48 00 267
1 STONE PROTECTOR,SIDE PANEL,LH (FOIL) 1 9197266 48 00 266
Thanks
1 STONE PROTECTOR,SIDE PANEL,RH (FOIL) 1 9197267 - £7.18+VAT (Retail £9.20+VAT)
1 STONE PROTECTOR,SIDE PANEL,LH (FOIL) 1 9197266 - £7.18+VAT (Retail £9.20+VAT)
Is this simply the stone chip[ protector plastic on the side of the car just behind the vents/turbo ears??
#408 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 28 July 2011 - 03:09 PM
STONE PROTECTION
Thanks
That's the bit Posted Image
#409 jbudgie
jbudgie
  • 521 posts
Posted 28 July 2011 - 05:13 PM
Not at the moment --just asking.
Not exactly sure what the problem is yet.
When you say exchange a bit cheaper -- any idea roughly. ?
#410 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 29 July 2011 - 07:43 AM
Found out why I can find a price - part not available Posted Image
If it's any consolation, it would have been about £200-£300 cheaper.
#411 out on the bike
out on the bike
  • 447 posts
  • Interests:fast bikes and fast cars
Posted 31 July 2011 - 06:06 PM
Hi could you give me a price and availability on a set of exhaust valves,valve springs and exhaust manifold bolts for the z20let Thanks.
#412 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 02 August 2011 - 08:25 AM
Std exhaust valve - 90410816 - £54+VAT each (Retail £70+VAT each)
EPC also lists another two exhaust valves, 0.075mm oversize, 0.15mm oversize. I can get prices on those too if you need.
Valve spring - 90448050 - £4.55+VAT each (Retail £5.80+VAT each)
The manifold studs are - 55355571 - 71p+VAT each.
If you let me know which ones you want to go for, I'll check availability. Posted Image
#413 out on the bike
out on the bike
  • 447 posts
Posted 02 August 2011 - 06:12 PM
Hi are you sure the £54+VAT for the exhaust valve is each and not a set of 8.I will get back to you on exactly which bitomorrowl require tommorow as I have got to take the old valves out to check whether I will require valves and springs or just valves or springs and I will probably just stick with the standard size though a price on the oversize would be good in case I decide to fit larger valves Thanks
#414 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 03 August 2011 - 07:49 AM
Unfortunately, that is per valve. But I am told that you want to go to Parkers / local non-genuine parts place, and I quote "They're like £5".
Worth a phone call though as it would save you about £480.
#415 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 03 August 2011 - 08:45 AM
Found a price for the over sized valves. The 0.075mm - £60+VAT each (No retail price listed) The 0.15mm - £89+VAT each (No retail price listed)
#416 out on the bike
out on the bike
  • 447 posts
Posted 03 August 2011 - 08:11 PM
Thanks for the pointer to parkers I will give them a try if I need them as I have taken the old ones out and my untrained eye can't see anything wrong with them other than I know they aren't sealing properly.I still can't believe how much vauxhall charge for them but thanks for taking the time to get the prices for me.
#417 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 04 August 2011 - 07:34 AM
No problem at all Posted Image
Hopefully it can in as in-expensive as possible for you.
#418 vectraboyv6
vectraboyv6
  • 117 posts
  • Interests:Train Driving, Hot tubbing, Beer
Posted 19 August 2011 - 02:56 PM
hi, can you quote for, 1 service book replacement 2 passenger internal door handel surround ( triangle piece) soory no part numbers stu
#419 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 19 August 2011 - 03:04 PM
stu
Can do Stu.
Service books are £18 inc.VAT
Well, I've learnt something new today, that bit is called an "escutcheon".
Have you got an N/A, VXT or VXR? The trim codes are different.
Edited by AstonVauxhall, 19 August 2011 - 03:04 PM.
#420 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 19 August 2011 - 03:05 PM
stu
Can do Stu.
Escutcheon - an item of door furniture that surrounds a keyhole or lock cylinder
