Car Won't Start
#21
Posted 23 March 2011 - 05:05 PM
#22
Posted 23 March 2011 - 05:20 PM
Can't imagine all of the plugs have terminally expired at exactly the same time, so don't think it will be those.
Did you ever check to see if you were getting fuel at the fuel rail?
Willing to give it a try. How exactly please?
#23
Posted 23 March 2011 - 05:23 PM
#24
#25
Posted 23 March 2011 - 05:24 PM
On the fuel rail there should be a little plastic cap covering a schrader valve like on tyres. Press this in and fuel should come out under pressure. Use a cloth to stop it spraying on you and dont smoke at the same time
Turn the ignition on and off a couple of times to make sure the pump (tries to) pressurises the fuel line.
#26
Posted 23 March 2011 - 05:30 PM
#27
Posted 23 March 2011 - 05:37 PM
#28
Posted 23 March 2011 - 06:15 PM
#29
Posted 23 March 2011 - 06:19 PM
I tentatively poked it, and some fuel came out. So now I've gone back and given it a good poke, but fuel dribbled out. So I turned the ignition on, and could hear a whirring noise (fuel pump?) after about 4 seconds. Pressed the valve again, but nothing seems to be coming out. Should the fuel pump pressurise the rail with the ignition on, so that there's a strong squirt?
Yes should be a good squirt once the ignitions on
#30
Posted 23 March 2011 - 06:22 PM
Edited by Horace, 23 March 2011 - 06:31 PM.
#31
Posted 23 March 2011 - 06:29 PM
#32
Posted 23 March 2011 - 06:39 PM
#33
Posted 23 March 2011 - 06:40 PM
#34
Posted 23 March 2011 - 06:48 PM
#35
Posted 23 March 2011 - 06:51 PM
#36
Posted 23 March 2011 - 06:55 PM
#37
Posted 23 March 2011 - 06:59 PM
Do you have fuel in the tank. Or are you parked on a slant?
I may be back in Donny this weekend. Not sure yet but could pop over to barnsley if i am
Tank is half full (must be an optimist). Car is in lincolnshire, so no slants!!
Offer of popping over muchly appreciately, but unfortunately the car is sat on the drive in Newark
#38
Posted 23 March 2011 - 07:37 PM
I think it might be wise to invest in a new battery before I try anything else. Thoughts?
#39
Posted 23 March 2011 - 07:39 PM
#40
Posted 23 March 2011 - 07:53 PM
