Edited by Horace, 23 March 2011 - 08:31 PM.
Car Won't Start
#41
Posted 23 March 2011 - 08:24 PM
#42
Posted 23 March 2011 - 08:29 PM
'FLD', on 23 Mar 2011 - 7:53 PM, said:
This sounds familiar! I had starting issues ages ago. When you press the fuel rail valve you should have a good metre jet! Mine cleared the car and went up the wall of the house! What I was finding was that the internal valves in the pump had failed. The pump primed but the pressure went straight away. Was a slag to start. Have a try at this....turn on the ignition and listen for the pump priming. DO NOT TRY TO START IT. Turn it off. Do this on / off routine several times and hopefully it should retain enough pressure. Then try to start it. If it starts the pump will run continuously and you'll be fine. Let us know how you get on. After swapping my pump its been fine. I also noticed how loud the old pump was compared to the new one. If it is your pump let me know as I have a cliffie pump to fit (been on the to do list for ages) so my old one will be going spare.
Did you have the metre jet with the knackered fuel pump? Or was that after the fix? How did you diagnose the internal valves?
Will try your method tomorrow. Thanks.
#43
Posted 23 March 2011 - 09:08 PM
Edited by FLD, 23 March 2011 - 09:09 PM.
#44
Posted 23 March 2011 - 09:13 PM
#46
Posted 23 March 2011 - 09:19 PM
#47
Posted 23 March 2011 - 09:33 PM
Edited by Horace, 23 March 2011 - 09:48 PM.
#48
Posted 23 March 2011 - 09:37 PM
'Horace', on 23 Mar 2011 - 9:33 PM, said:
Yep, it's not a job to undertake just for the fun of it.Jesus!
I'm not sure it will. As long as you don't mangle the float for the fuel level sender, it should make no difference. Mine has been fine with the upgrade to the ProAlloy long range tank and the later fuel pump upgrade. At least I think it has, I haven't run out of petrol yet.Why will the guage read differently?
#49
Posted 23 March 2011 - 09:59 PM
Edited by Horace, 23 March 2011 - 10:00 PM.
#50
Posted 23 March 2011 - 10:03 PM
'Horace', on 23 Mar 2011 - 9:59 PM, said:
Just a thought (in desperation):
If my battery is on its last legs, and it's the only thing that powers the fuel pump when priming the system, could it be that there's not enough juice (power) to properly pressurise the system?
I would doubt it as the cranking the engine is where I would expect the largest battery load to be... So if the engine is turning then surely there must be enough charge to prime the fuel rail.
#51
Posted 23 March 2011 - 10:06 PM
#52
Posted 24 March 2011 - 12:48 PM
#53
Posted 24 March 2011 - 12:58 PM
'FLD', on 24 Mar 2011 - 12:48 PM, said:
Maybe mine has taken to under-reading then and that's why I've spent the last 3 trackdays watching fuel cascade out of the filler on left handers, in the side mirrors. A little more worrying now I've got a de-cat and the possibility of flames coming out of the exhaust. Rear clam was absolutely dripping in fuel at Snetterton after a top up (too theoretically about 36 litres of the 48 litre tank).Having swapped it it now seems to read high. I always err on the side of caution now and keep it full!
No idea why it's suddenly started doing it.
#54
Posted 24 March 2011 - 01:45 PM
Be careful Matt... One VX has already been lost to a fire in the last 12months (RIP Kerry) and we don't need another going that way.
Coincidentally mine always under reads by 2 litres - but other than the effect of petrol sloshing in the tank on corners it is always bang on right (when you add the missing 2litres to the digital read out).
#55
Posted 24 March 2011 - 10:24 PM
Here's a piccy of the 2 multicore plugs behind the header tank. They look manky but they were clean and dry inside.
Here's a piccy of the ECU earth strap. I cleaned the connection up, but it really wasn't suspect
So I decided to have a look at the relays in the boot. I had a peer inside and saw the relay cover. The screws were a right pita to get out and the rubber inserts just spun round in the wheel arch. After much swearing and pissanting about, I managed to get the cover off..... and was presented with a small motorcycle battery! Doh!!
So I started taking the right cover off this time, but had to take the boot carpet and liner out for access. Here's what I found (boot floor)
And the relays and cabling were looking decidedly damp
Notice how the relays are marked up to match the coloured stickers. Has this been worked on before?
Took the relays out. Some of the relay sockets were showing signs of oxidisation. I'll need to clean these up somehow.
One of the grey relays was a little oxidised on the main contacts, but not major. The others were all okayish. I took the relay covers off just to be sure, and all looked clean and dry in there.
I cleaned all the contacts up with emery paper no problem.
#56
Posted 24 March 2011 - 10:26 PM
Those two yellow 20A fuses look in very bad shape. They haven't blown, but the plastic has melted and bubbled, and one of the contacts in particular has a thick coating of melted crap and oxidisation on it.
The main 50A fuse had oxidisation of one of the contacts, but looked healthy otherwise.
This is my prognosis (fingers crossed): I suspect that these fuses have been shorting out due to dampness. The heat generated has melted the plastic. Because they've been shorting before the actual 'fuse' element, the fuse hasn't blown. The shorting out of these fuses has lead to not enough power being fed to the fuel pump, so the fuel pump hasn't enough juice to pressurise the fuel rail. The deterioration of these fuses would coincide with the gradual onset of my issues (rather than a fuse blowing and the issue becoming immediately apparent).
I've got replacement fuses. And tomorrow I'm back in the boot.
Wish me luck!
#57
Posted 24 March 2011 - 10:40 PM
#58
Posted 24 March 2011 - 10:44 PM
#59
Those fuses look promising........
#60
Posted 24 March 2011 - 10:56 PM
