The engine was making a grinding noise when giving it beans in 2nd so i decided to replace the side mounts, the drivers side had actually collapsed
Anyway - I get the feeling these things normally last about 40k miles? This one was original and has done nearly 85k miles!
Is that a record?
It must have been broken for a LONG time, the broken fragments had corrosion on the fracture lines and the actual engine mount arm had some pretty bad wear!
God knows how the previous owner lived with it for so long.........
