Team Jerusalem's 2011 Time Attack
#241
Posted 27 June 2011 - 07:37 PM
#242
Posted 27 June 2011 - 07:46 PM
Because that cylinder has the worst fuel and air supply so gets to dangerous temperature before the rest! If it then detonates without compression it burns the end of the plug off and that's what's happenned to us.
Exactly so the thing to do is solve the initial problem of it having an inferior or inadequate supply than the others. Swirl pot and/or, if possible/available a larger fuel rail??
We're not discussing a fueling issue though Mark, we're discussing the loss of full compression due to a lifting valve. In this case the fuel ignites in the cylinder and just burns the plug. The cylinder with poorest supply will still be the first to fail no...?
#243
Tool thieving northern monkey
careful you... otherwise i might turn into a harrop thieving monkey
#244
Posted 27 June 2011 - 07:48 PM
ho ho ho ho you lot really crack me up
Not you mr uk sutol Chris you northern monkey
i dont have a standard head..
well its a standard head but machined for better valves, unless thats what you meant.
and i do drive like miss daisy, ask cliffie.. lol. i drove back from brands on sunday after filling up and ive still got 8L left in the tank.. i averaged about 38mpg and that was with the roof off! lol
what about the FPR could that be adjusted or uprated?
#245
Posted 27 June 2011 - 07:51 PM
Not without remapping....?
#246
Posted 27 June 2011 - 08:02 PM
#247
Posted 27 June 2011 - 09:34 PM
We did adjust the FPR Jimmy, with the socket and the momentum shifting device.
I am convinced this is not a fuelling issue, it is an electrical breakdown under load.
A swirl pot is a good idea Jimmy but I doubt you will need a Bosch 044 pump as well, the in tank pump you have is up to the job. The only reason people went for the 044 was to try to get around the issue of poor performing standard and failing in tank pumps.
#248
Posted 27 June 2011 - 09:46 PM
Sounds like it was a weekend to remember! I hope the next one is less frantic!
I was really hoping to make it there on Saturday, but had to change my plans at the last minute.
Hopefully your car will be flying again at full strength soon!
It better be Max, you and I are at Cadwell a week Wednesday
...yeah, the B&B is booked!
#249
Posted 27 June 2011 - 10:22 PM
The intank pump will be fine aslong as you always run high amounts of fuel. I still think he should fit a swirl pot and 044 pump though
#250
Posted 28 June 2011 - 03:20 PM
#251
Posted 28 June 2011 - 03:28 PM
Report is up on the time Attack Website http://www.timeattac...a=1&s=235&p=235
confused, so did your car have a rollcage for round 1 of the 2?
#252
Posted 28 June 2011 - 03:29 PM
#253
Posted 28 June 2011 - 03:30 PM
You don't need a roll cage for club series
Reprase the question, from the typical trackday setup we run, what do the rules say you must have.
#254
Posted 28 June 2011 - 03:34 PM
#255
Posted 28 June 2011 - 03:36 PM
#256
Posted 28 June 2011 - 03:44 PM
#257
Posted 28 June 2011 - 05:35 PM
Thats just crying out for a saab track slag special.
Unless something has changed you could run unchallenged in the RWD NA class
#258
Posted 31 July 2011 - 08:43 PM
#259
Posted 31 July 2011 - 08:58 PM
#260
Posted 31 July 2011 - 08:59 PM
