Unless the water coming back in is hot. And the heat exchange may done in a different place, but there is still the air - metal - water - metal - air. So it isn't as efficient as an intercooler.
Siztenboots, I don't know why you are stoking this debate up again. It's been done to death - search is your friend
You beat me to it Spuk. Intercooler systems are more efficient that charge coolers. Because as you say with an charge cooler its air - metal - water - metal - air. With an intercooler its air - metal - air.
Also charge coolers may take longer to reach soak temp, but the more coolant you have, the more stored energy you have, the longer it takes to dissipate the heat.
And having the heat exchanger at the front is the same place where the engine radiator is, so you are dumping the heat in the area where the engine is dumping its heat.
It may be air-metal-water-metal- but you dont have to wait for the whole process to happen. So its basically air-metal-water and then that fooks off around the system leaving the next air-metal-water to happen straight away. And as water absorbs heat alot better then happy days.
Also even after alot of running you'd be lucky to increase the water in the cc system by a few degrees
But this intercooler isn't about intercooler vs chargecooler. It is a drop in replacement for the standard intercooler. The intercooler fitted to the car as it came out of the factory is shit. This is an intercooler that is practially the same size as the standard intercooler yet actually works properly for a standard turbo up to stage 3.
For stage 4, there is a bigger MMG intercooler.
Yep is a good replacement and all you need for the normal track weapon
The water doesnt get hot. a few degrees more even at the most arduous use
