Posted 31 March 2011 - 07:03 AM
Posted 31 March 2011 - 07:55 AM
Posted 31 March 2011 - 08:06 AM
Posted 31 March 2011 - 08:24 AM
Bosch Z22YH coil pack fits the z22se engine and has the same connector as the z20let
Posted 31 March 2011 - 08:46 AM
Posted 31 March 2011 - 08:55 AM
Posted 31 March 2011 - 08:58 AM
Posted 31 March 2011 - 09:13 AM
Have a look here: http://www.hofmanns....opa-ecu-upgrade
This will fit a VX too. Currently I need to cut the looms but just working on a plug and play version. Much, much better ECU than the DTA.
Posted 31 March 2011 - 09:38 AM
Posted 31 March 2011 - 09:48 AM
As you lack a camshaft sensor on the 2.2, I assume they removed this from the base-mapping?
So you now probably lack the sequential injection and only have "batch injector firing" with the Z20LET ecu on the 2,2??
Posted 31 March 2011 - 10:14 AM
correct on both accounts, I had toyed with the idea of some sort of cam sensor setup but nothing really came of it
Posted 31 March 2011 - 10:27 AM
Posted 31 March 2011 - 11:21 AM
Posted 31 March 2011 - 09:28 PM
Posted 12 April 2011 - 06:25 PM
Posted 12 April 2011 - 06:27 PM
Posted 12 April 2011 - 06:44 PM
if you have a template with dimensions on i can get one made
Posted 12 April 2011 - 06:45 PM
Posted 14 April 2011 - 09:36 AM
Posted 14 April 2011 - 01:21 PM
