Ecu Change
1497 replies to this topic
#241 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 27 May 2011 - 09:04 AM
hope it's sorted soon just can't believe this saga
#242 techieboy
Posted 27 May 2011 - 09:07 AM
Did they ever try mapping it with the standard cams in, to rule out any problems with the ECU/sensors/timing etc? Proper pain in the proverbial though. :(
#243 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 27 May 2011 - 09:58 AM
Nick,
This was never going to be as straight forward as a remap, this is ground breaking stuff and entering new territories for the VX220 and Courtenay's.
Things like this take time to get right and don't forget, folks like us really benefit from the investment you pioneers have made. (No I'm not going halves with you... ask Joe, he has a Harrop).
#244 VIX
VIX
  • 9,497 posts
Posted 27 May 2011 - 10:10 AM
:yeahthat:
I don't recall any development work on the VX being straightforward and always took way longer in time and £££ than expected. IIRC the original Hitec SC conversions were problematic. Stick with it mate. thumbsup
#245 Exmantaa
Posted 27 May 2011 - 10:19 AM
:yeahthat:... First go back to the basics.
Too many variables right now and very difficult to pinpoint the problem this way...
#246 NickB787
NickB787
  • 7,813 posts
Posted 27 May 2011 - 11:32 AM
Courtenays removed the Harrop and put on an m62 so then it is the same spec as a number of other s/c cars running 300bhp car still ran rough with the cams in worse than other m62 cars, so cams seem to be the thing and looking back to the original fit with the z22se ecu it was rough then so think it was probably the cams all along. will see when piper check them.
#247 The Batman
Posted 27 May 2011 - 11:33 AM
I would wanna fit standard cams though to make sure that the timing with the external trigger wheel is alright
#248 NickB787
NickB787
  • 7,813 posts
Posted 27 May 2011 - 11:35 AM
They have already checked that and it was almost spot on, nats wisker Jon said
#249 Exmantaa
Posted 27 May 2011 - 12:25 PM
Slightly off topic; what's the trigger clocked at? 114° BTDC, measured on centre of 1st missing tooth?
#250 Exmantaa
Posted 27 May 2011 - 05:23 PM
Edit: got confirmed on Z22SE.co it's indeed 114* BTDC for the centre of the 1st missing tooth on a 60-2 GM wheel.
#251 Exmantaa
Posted 27 May 2011 - 10:54 PM
OK, forget the above for a GM 2.0 LSJ crank trigger:
Printed a degree wheel and put it on my 2.0 LSJ crank:
- Zeroed degree wheel on TDC mark => 0*
- Rotated LSJ crank clockwise till centre VR sensor lined up with centre 1st new tooth after the 60-2 gap => ~119* BTDC !
- Rotated crank further clockwise till TDC mark on pulley => 0* again. (Checked TDC mark on pulley through plug = highest point cil 1.)
So my 2.0 LSJ engine has the centre of the 1st new tooth after the 60-2 gap (rotating crank clockwise) on 119* BTDC, so centre of 1st missing tooth is around 131* BTDC. (119*+12*)
The above is measured on a GM 2.0 LSJ engine with 60-2 triggerwheel (similar to Z20NET/Saab 207 crank?) and thus I'm not sure on triger timing for the Z20LET engine (ecu) or on the Z22YH crank triggerwheel.
But if I would allign my triggerwheel with 1st missing tooth on 117* BTDC, my LSJ ecu timing would be off by 14*... (Retarded!!)
#252 NickB787
NickB787
  • 7,813 posts
Posted 27 May 2011 - 11:09 PM
I am just having a look again at this, I did use 117 Before DTC I will have to do this later I am seriously tired tonight and can't think straight
Edited by NickB777, 27 May 2011 - 11:14 PM.
#253 NickB787
NickB787
  • 7,813 posts
Posted 27 May 2011 - 11:29 PM
wonder if it's possible to use the old fashioned timing light to check ?
#254 Exmantaa
Posted 27 May 2011 - 11:30 PM
Yeah, it's confusing and therefore I started measuring. Would be nice if somebody could measure up the Z20LET crank trigger. (And do like to know how Courtenay checked your timing.)
#255 Exmantaa
Posted 27 May 2011 - 11:34 PM
That works with some extra timing marks on the pulley and when you know how much timing the ecu commands. (Or program 0* timing advance and the strobe should be dead on the pulley mark...)
#256 NickB787
NickB787
  • 7,813 posts
Posted 27 May 2011 - 11:44 PM
I wonder, might explain it if its that far out!! (14 degrees)
#257 Exmantaa
Posted 27 May 2011 - 11:52 PM
That will make a nice afterburner indeed... :blink:
#258 NickB787
NickB787
  • 7,813 posts
Posted 27 May 2011 - 11:54 PM
will keep looking
Edited by NickB777, 28 May 2011 - 12:01 AM.
#259 NickB787
NickB787
  • 7,813 posts
Posted 28 May 2011 - 12:33 AM
I posted a question on the MIG forum, will see if I can get any information
#260 NickB787
NickB787
  • 7,813 posts
Posted 28 May 2011 - 11:11 AM
just spoke to a vauxhall chap and he thinks the z20let has the same timing as the z20net.
    Bing (1)
