Ecu Change
1497 replies to this topic
#261 Exmantaa
Posted 28 May 2011 - 12:27 PM
Found there is a difference in 60-2 (or GM 58X) reluctor timing between the US 2.0 LSJ engine and the later 2.4LE5 (and later 2,2 L61's with 58X):
http://www.redlinefo...-thread-18.html
Quote: The crank ring is off by 12 deg (difference between LE5 and LSJ). You would need to replace the ring on the LE5 crank with the LSJ ring.
So this could mean that my 2.0 LSJ (and so maybe the Saab/Z20NET too) is just differently timed than the Z20LET engine, explaining the 14* difference I found.
Somebody should simply measure up a Z20LET...
#262 Exmantaa
Posted 28 May 2011 - 02:29 PM
OK, after some Googling I'm getting seriously confused with all info.
For the Vauxhall 2.0-16V 60-2 pattern I found:
114* BTDC
120* BTDC
126* BTDC
Conflicting info, but seems due to what tooth all this is measured to (1 tooth = 6*)
http://www.msextra.c...gger-wheel.html =>
Bosch 4 cyl (Peugeot, Vauxhall) = 60-2, 114 deg tooth #1
Note this is on tooth #1, meaning the 1st tooth after the gap, rotating clockwise...
http://www.scribd.co...Vauxhall-engin4
Info on trigger wheel settings was on thevaux-extreme forums somewhere but I cant find the page, by they way which is an awesome forumfor information for megasquirting our engines. The main value that is important is the Degreesbefore TDC or trigger offset, depending on which menu-set you have in megatune, and whatfirmware you run. The degrees before TDC is 126 (360 degrees divided by 60 teeth, timesby 21). The offset is 21 for the Vauxhall 60-2 trigger wheel
#263 alanoo
alanoo
  • 1,324 posts
Posted 28 May 2011 - 03:05 PM
I said that many times before, but there is no reason at all the ref position will be the same between different vauxhall engine with the same trigger pattern I won't be surprised it is different between a Z20LEx, a LSJ, an LE5, a 07+ US L61, a Z16 or any other one... each with a different angle
#264 Exmantaa
Posted 28 May 2011 - 03:19 PM
Digged a little more on several stand alone forums and again read there that the missing teeth on a 2.0-16V VX engine are at 120* and 126* BTDC, what corresponds to the above 114* for the 1st tooth after the gap.
If you have clocked your trigger wheel at 117* BTDC for centre 1st missing tooth, your ignition will occur 9* later than commanded...
Post #14: Posted 31 March 2011 - 10:28 PM
Seemed to ahve found the answer to the trigger wheel angle and where it is measured from
117* BTDC is then measured from the centerline of the first missing tooth
Edited by Exmantaa, 28 May 2011 - 03:25 PM.
#265 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 28 May 2011 - 04:50 PM
Thats what I set it too I will speak again to Courtenays on Tuesday, the information out there can be a real pain to sift through
#266 NickB787
NickB787
  • 7,813 posts
Posted 03 June 2011 - 09:47 AM
update all I can say at the moment is it is the cams rant
#267 FLD
Posted 03 June 2011 - 09:51 AM
update
Thats irritating! At least now the problem has been found and it should all be down hill from now. The end is in sight and we are all waiting on the edge of our seats for the BIG number!
#268 NickB787
NickB787
  • 7,813 posts
Posted 03 June 2011 - 10:10 AM
PM sent Matt
#269 vocky
Posted 03 June 2011 - 10:38 AM
Courtenay should be able to adjust the timing for different crank trigger wheels as the ECU is supposed to be fully cracked
#270 Exmantaa
Posted 03 June 2011 - 12:29 PM
:yeahthat: But that implies that they must check the crank timing first before they start mapping these conversions. But good to hear that you find that the source of your problems is cam related, but interested in what really caused it.
#271 NickB787
NickB787
  • 7,813 posts
Posted 03 June 2011 - 01:19 PM
Me too, I am awaiting the spec sheet from Piper so I can see what cams they really are
#272 NickB787
NickB787
  • 7,813 posts
Posted 05 June 2011 - 07:56 AM
found the coil pack cover for the z22yh 24454399 - £5+VAT (Retail £6.05+VAT) vauxhall dealer
#273 The Batman
Posted 05 June 2011 - 05:05 PM
Where would I put the pipe for the Charcoal canister valve? As normally it connects to the tb but the Porsche one doesn't have this.... Do I put a pipe connector into the air filter and put it there? Or will it try and suck fumes from the tank?
#274 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 05 June 2011 - 05:07 PM
Yes put it to the intake pipe mate it will be fine thumbsup
#275 The Batman
Posted 05 June 2011 - 05:08 PM
chinky chinky
#276 NickB787
NickB787
  • 7,813 posts
Posted 05 June 2011 - 05:56 PM
thats what I'm doing
#277 Exmantaa
Posted 05 June 2011 - 10:22 PM
I have my EVAP valve connection on the top of the SC, behind the TB so always on vacuum. Think this is also unused by your builds?
#278 The Batman
Posted 05 June 2011 - 10:33 PM
Got a picture of what you mean?
#279 NickB787
NickB787
  • 7,813 posts
Posted 06 June 2011 - 03:39 PM
think thats the blanked bolt hole on top of the harrop
#280 The Batman
Posted 06 June 2011 - 03:57 PM
Oh right yeah don't use them/have no use for them! I'm gonna run it in p clips down the bulkhead as trying not to make my engine bay look cluttered :blush:
    Bing (1)
