The normal EVAP pipe on TB connects also to the vacuum side, so the top of the charger should give a similar effect.
pic:
How's the ecu/camshaft doing? Any updates on what was wrong?
Edited by Exmantaa, 06 June 2011 - 04:03 PM.
Posted 06 June 2011 - 04:01 PM
Posted 06 June 2011 - 04:07 PM
Posted 06 June 2011 - 04:17 PM
Posted 10 June 2011 - 09:42 AM
Edited by NickB777, 10 June 2011 - 09:45 AM.
Posted 10 June 2011 - 10:22 AM
Posted 10 June 2011 - 10:34 AM
Posted 10 June 2011 - 12:18 PM
No thats great thanks
no reason then why it can't be checked. I had also on a side not thought about getting a set of LSJ cams from the states as these were designed for the s/c, wonder if they would work, don't see why not
Posted 10 June 2011 - 01:01 PM
Posted 10 June 2011 - 01:04 PM
Posted 10 June 2011 - 01:05 PM
Posted 10 June 2011 - 01:21 PM
to take account of the oem s/c attached?I'd suspect they just reduced the overlap.
Posted 10 June 2011 - 01:24 PM
Posted 10 June 2011 - 01:28 PM
Posted 10 June 2011 - 01:38 PM
Posted 10 June 2011 - 02:24 PM
Who has the comp blower cam install sheet which came with the cams? I managed to misplaced mine, wonder what extra info is on it
Posted 10 June 2011 - 02:38 PM
Posted 10 June 2011 - 02:43 PM
Posted 10 June 2011 - 04:01 PM
I've got them. No more information than you've already got by the look of it. Intake cam is part no. 113251 and exhaust is part no. 113252. Can scan the spec sheets if you want but not sure it's going to help any?Who has the comp blower cam install sheet which came with the cams? I managed to misplaced mine, wonder what extra info is on it
Posted 10 June 2011 - 04:46 PM
thanks Matt sounds like there is nothing more
Posted 10 June 2011 - 06:46 PM
