Ecu Change
1497 replies to this topic
#301 Muncher
Muncher
  • 4,494 posts
Posted 20 June 2011 - 01:45 PM
Nick, I don't suppose you could post a list of the costs of the components for this ECU swap could you?
#302 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 20 June 2011 - 06:43 PM
yep will try to do it in the next few days, flat out at work at the moment. still no word will try to call Jon tomorrow when I get back from work
#303 FLD
Posted 17 July 2011 - 09:38 PM
Any updates Nick? Are you up and running?
#304 NickB787
NickB787
  • 7,813 posts
Posted 19 July 2011 - 07:20 PM
Think I might nip over there tomorrow and see how things are going
#305 VIX
VIX
  • 9,497 posts
Posted 19 July 2011 - 10:17 PM
I think that redefines the word "nip"! Good luck though, I hope there's some progress to report! thumbsup
#306 The Batman
Posted 20 July 2011 - 02:27 AM
I would ring first :ninja:
#307 NickB787
NickB787
  • 7,813 posts
Posted 02 August 2011 - 09:14 AM
She is running again and smoothly this time :groupjump: might even get her on the dyno today
#308 techieboy
Posted 02 August 2011 - 09:15 AM
Woooooohoooooooo. thumbsup Any idea on what they did?
#309 NickB787
NickB787
  • 7,813 posts
Posted 02 August 2011 - 09:30 AM
I sent them the Saab cam gears, same as oem but no positioning lugs on them, so they needed to adjust them manually. sounded a bit of a pain to do, but they did it. It does sound like all my hassle right back to the start of this episode may have been due to the comp cams not having the lug in the correct position. rant rant rant (worth 3 IMHO)
Edited by NickB777, 02 August 2011 - 09:31 AM.
#310 vocky
Posted 02 August 2011 - 09:32 AM
you should always vernier the cams on big power engines :closedeyes: mine were something like 2 degrees and 6 degrees out :rolleyes:
Edited by vocky, 02 August 2011 - 09:33 AM.
#311 techieboy
Posted 02 August 2011 - 09:38 AM
IIt does sound like all my hassle right back to the start of this episode may have been due to the comp cams not having the lug in the correct position.
Which brings the inevitable question of whether they could now do the necessary mapping for the Harrop on the Z22SE Delphi ECU. :unsure: :beat:
Still, at the end of the day, you'll have a much more flexible ECU in there now that they can properly tinker with. thumbsup
#312 NickB787
NickB787
  • 7,813 posts
Posted 02 August 2011 - 09:41 AM
Mr Vocky I wish I had known this earlier say 2.5 years earlier :lol: could have saved me a fortune :( , and as for Mr Techieboy don't think of going there :beat:
#313 techieboy
Posted 02 August 2011 - 09:43 AM
Define big power. Should I be worrying......... :wacko:
#314 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 02 August 2011 - 09:55 AM
And FLD will have the same issues. As soon as Jon told me what was happening we knew the exhaust cam was the culprit.
#315 vocky
Posted 02 August 2011 - 09:57 AM
I would advise using them with Blower cams and a Harrop.
Max has them in his engine because he was going to fit a Harrop (his Blower cams were only a degree or two out) and my engine has them because I wanted the absolute maximum from the stage 3 cams.
#316 NickB787
NickB787
  • 7,813 posts
Posted 02 August 2011 - 09:58 AM
Amazing comp cams can sell stuff which is not fit for purpose how much money has this cost me, £1000's
#317 NickB787
NickB787
  • 7,813 posts
Posted 02 August 2011 - 09:59 AM
I would recommend anyone with blower cams to pick up some Saab cam gears and set them up propperly
#318 techieboy
Posted 02 August 2011 - 10:11 AM
Unless CompCams are just making random cams then I can't see how there's an inherent problem with them. Surely, the problem is down to them i) not being for this exact engine (but for a similar engine) and, ii) down to fitting and us just assuming they work correctly straight away, as they physically fit.
I for one don't like the sound of my cams being out by a degree or two or more. That's surely not doing any favours to the valvetrain or combustion chambers, nor delivering peak power. Maybe that's why with blower cams in, the idle is as lumpy as it is.
Time for Mushroom Racing to call in some contacts at Piper or Kent Cams and get them to make some sensibly priced Verniers suitable for the Z22SE? :unsure:
#319 NickB787
NickB787
  • 7,813 posts
Posted 02 August 2011 - 10:38 AM
:yeahthat:
#320 FLD
Posted 02 August 2011 - 12:15 PM
You should always always always check the cam timing on any engine. I think this is one of the biggest critical factors on an engine running properly. Adding something like a turbo or supercharger into the equation just magnifies the issue. I looked at the OE timing gears with the lug and the ones I had allowed a couple of degrees float on each cam anyway. Not the best locking method! Glad I still have some saab gears now.
Its good to hear you are up and running Nick. I'm looking forward to seeing a dyno plot on that beastie.
