Ecu Change
#361
Posted 13 September 2011 - 12:26 PM
#362
Posted 13 September 2011 - 12:39 PM
Is "fit a standalone" an acceptable idea ?
No!
#363
Posted 13 September 2011 - 01:19 PM
Edited by Exmantaa, 13 September 2011 - 01:19 PM.
#364
Posted 13 September 2011 - 01:35 PM
#365
Posted 13 September 2011 - 02:08 PM
#366
Posted 13 September 2011 - 02:20 PM
#367
Posted 13 September 2011 - 02:40 PM
Edited by NickB777, 13 September 2011 - 02:41 PM.
#368
Posted 13 September 2011 - 03:01 PM
#369
Posted 13 September 2011 - 03:17 PM
Shouldn't that just retard the ignition? Are there any fault codes?as it's set up for a different engine could it be reading engine vibrations as knock? or are these filtered out?
#370
Posted 13 September 2011 - 03:31 PM
#371
Posted 13 September 2011 - 03:54 PM
Since the beginning of this ECU swaps story I said I couldn't see how an iron block/cam belted engine knock filter setup could work without issue on an alloy engine with a chain which is waaaaaayyyyy more noisy.
Still I doubt it is the issue here, and if it is it should work by simply changing the torque of the sensor bolt or simply removing it ?
My guess is more around a MAF issue, do they use a MAF sensor as on the z20LET ?
Edited by alanoo, 13 September 2011 - 03:55 PM.
#372
Posted 13 September 2011 - 04:10 PM
Yes they do
#373
Posted 13 September 2011 - 04:35 PM
#374
Posted 13 September 2011 - 06:22 PM
#375
Posted 13 September 2011 - 06:28 PM
Great newsThey might have it
#376
Posted 14 September 2011 - 03:45 PM
#377
Posted 14 September 2011 - 03:48 PM
#378
#379
Posted 14 September 2011 - 03:49 PM
#380
Posted 14 September 2011 - 03:51 PM
they moved the drivers seat further forward
was to do with software and the dump ( amal) valve on the turbo setup I am certain Jon will tell all when he gets time
6 user(s) are reading this topic
Bing (3)
