Ecu Change
1497 replies to this topic
#521 Winstar
Winstar
  • 4,264 posts
Posted 04 November 2011 - 12:34 PM
Surely the easiest solution (not even that easy) is to redesign the intake manifold and retain the existing CC setup?
The benefit with that is you could flog a whole load of them to cover your costs.
it's nothing to do with the design of the manifold it's self it's the fact that the laminovas are not sized for the flow or heat that people are throwing at them, it is working well beyond the design at stg 2.
#522 The Batman
Posted 04 November 2011 - 12:36 PM
I think around the 380-400mark is right anything more and you are getting dangerously close to liner issue... I tested when the rods and pistons would snap and I defiantly am not testing the liners!!! I have a few ideas about cc systems so once I'm up and running I can tinker about with then :)
#523 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 04 November 2011 - 01:12 PM
You could always use my charge cooler rad; 50% more capacity than the Pro Alloy set up.
#524 The Batman
Posted 04 November 2011 - 01:16 PM
i dont need capacity as of my large coolant tank the radiator area is still the same as my pro alloy one
#525 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 04 November 2011 - 01:21 PM
No it isn't, the surface area of mine is greater than yours however your willy is still longer (I am told).
#526 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 04 November 2011 - 01:54 PM
No it isn't it is the same size actually. Or is mine wider? Yup, I think mine is wider.
#527 The Batman
Posted 04 November 2011 - 02:02 PM
no just has bigger headers thumbsup
#528 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 04 November 2011 - 02:57 PM
Courtenays just posted a link up to you tube video
#529 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 04 November 2011 - 03:07 PM
And a bigger core.
#530 The Batman
Posted 04 November 2011 - 03:09 PM
yeah thicker core i maybe changing to a standard radiator so that i have an inlet outlet on each side as i may run extra radiators....
#531 techieboy
Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy Imnotworthy
#532 NickB787
NickB787
  • 7,813 posts
Posted 04 November 2011 - 03:12 PM
it did seem to lift a bit on the rollers!, what gear do they use third or forth? it showed 138 I am wondering if they have removed to limiter on the ecu?
Edited by NickB777, 04 November 2011 - 03:14 PM.
#533 techieboy
Posted 04 November 2011 - 03:14 PM
Think they use 4th. 37mph to 138mph all in one gear. Covers most eventualities. :D
#534 NickB787
NickB787
  • 7,813 posts
Posted 04 November 2011 - 03:16 PM
should make overtaking a bit easier now :lol:
#535 techieboy
Posted 04 November 2011 - 03:18 PM
Lovely SC torque "curve" again. :wub: What clutch are you running in there? Will be interesting to see if you now start running into the problems the >Stage 2 tubbie boys do. Though I guess the SC delivery is a bit more clutch friendly than a sudden massive dollop of torque.
#536 NickB787
NickB787
  • 7,813 posts
Posted 04 November 2011 - 03:23 PM
It's the Courtenay uprated clutch that has been in the car since the original conversion 6 years I think, I am hoping that because the torque is almost a straight line I won't have the same issues that the tubby guys have
#537 smiley
Posted 04 November 2011 - 03:38 PM
Amazed to see the outlet manifold not turning red when it's peaking :blink:
#538 Nev
Posted 04 November 2011 - 03:50 PM
If you have a Helix or Sach paddle plate and cover then you will be fine for way more torque. And as someone has already pointed out, you SC chaps don't push transient torque peaks through the drive train, so it's way more clutch friendly :) That dyno graph should make it a complete pussy cat to drive around when you go out shopping to Tesco ;) Whats the idle set at and is it lumpy? Is the car to be MOTed and taxed BTW (ie a road car as well) ?
#539 PaulCP
PaulCP
  • 6,066 posts
Posted 04 November 2011 - 03:51 PM
The last set of figures to come out were 377bhp and 304lbs at 7300rpm on an 80mm pulley. Temp in the dyno area was about 20 C.
Think i will leave it at that, peak power was about 7300rpm, inlet temp reached 60C so realistically if I want more than say 390bhp I would be into some extra cooling of the intake manifold itself as even extra coolant capacity would just delay the inevitable.
Mapping was MUCH easier with the z20let ecu my 470cc injectors worked fine and weren't maxed running 4.5 bar
so all in all VERY please, well done Courtenay :Imnotworthy Imnotworthy chinky chinky :groupjump:
Well done Nick thumbsup finally got there
i think my wife is going to hate you when we get back :rolleyes: it will be all your fault
#540 Nev
Posted 04 November 2011 - 03:53 PM
There is no turbo 'bottling up' the exhaust gases, so it's not normal to see the manifold runners glowing unless it is running super lean. Also, you can see he has big I/D on his runners and a good design which all helps flow the gas straight out.
