Edited by joe_589, 04 November 2011 - 03:57 PM.
Posted 04 November 2011 - 03:55 PM
Posted 04 November 2011 - 04:01 PM
Don't hold your breath. I've booked all of the spare slots until April.to see when i can book mine in
Posted 04 November 2011 - 04:02 PM
Posted 04 November 2011 - 04:05 PM
Posted 04 November 2011 - 04:08 PM
Posted 04 November 2011 - 04:15 PM
If you have a Helix or Sach paddle plate and cover then you will be fine for way more torque. And as someone has already pointed out, you SC chaps don't push transient torque peaks through the drive train, so it's way more clutch friendly
That dyno graph should make it a complete pussy cat to drive around when you go out shopping to Tesco
Whats the idle set at and is it lumpy?
Is the car to be MOTed and taxed BTW (ie a road car as well) ?
The last set of figures to come out were 377bhp and 304lbs at 7300rpm on an 80mm pulley. Temp in the dyno area was about 20 C.
Think i will leave it at that, peak power was about 7300rpm, inlet temp reached 60C so realistically if I want more than say 390bhp I would be into some extra cooling of the intake manifold itself as even extra coolant capacity would just delay the inevitable.
Mapping was MUCH easier with the z20let ecu my 470cc injectors worked fine and weren't maxed running 4.5 bar
so all in all VERY please, well done Courtenay :![]()
Well done Nickfinally got there
i think my wife is going to hate you when we get backit will be all your fault
Edited by NickB777, 04 November 2011 - 04:16 PM.
Posted 04 November 2011 - 04:22 PM
Got two more here. Feel free.
Posted 04 November 2011 - 06:20 PM
Posted 09 November 2011 - 05:29 PM
Posted 09 November 2011 - 05:34 PM
Just realised what's missing on that video. Absolutely no SC noise.
Posted 12 November 2011 - 09:35 AM
Posted 12 November 2011 - 09:36 AM
Posted 12 November 2011 - 10:57 AM
Edited by Nev, 12 November 2011 - 10:57 AM.
Posted 12 November 2011 - 11:39 AM
Information for anyone doing this mod I found out that the bhp we achieved was done not with the OEM pulley(80mm) as I thought but with a 2.8" I had imported and fitted myself.
strange I would have thought it would have made more than 380bhp with it on
Posted 12 November 2011 - 04:53 PM
Sorry Nev not certain what you mean.Engines depressingly become less and less efficient at high revs. Mine did the same and tails off more than I hoped.What's the smallest sized pipework in your system ?
Posted 17 November 2011 - 08:17 PM
yep think thats it with this intake manifold.
Edited by Nev, 17 November 2011 - 08:17 PM.
Posted 17 November 2011 - 08:39 PM
Sorry I should have been clearer, I mean you need to identify what the bottleneck in the engine's 'breathing' is. As you are probably aware an engine's ability to make power is directly proportional to the amount of air you can pass through it in a given time. From this premise you can extrapolate that you need to improve the way the air enters and exits the engine. Usually it is things like too narrow pipework, manifolds, TBs, inlet runners, exhausts etc that cause these issues.
To illustrate this (using a 200 BHP standard VXT as an example), the tophat has an I/D of 49mm. This means it has a cross sectional area of 1886 mm sq. A 200 BHP engine requires 8500 Litres/min. From this we can calulate the air speed through that tophat will be 270 KPH. Clearly a restriction. This is why replaceing that part with a bigger diam. equiv yeilds more torque and hence power.
Once you are trying to force 380 BHP out of your OEM engine just about every part (that air travels though) in it needs to be replaced or it will be a restriction. I am assuming CS have done this but if it were my car, I'd be double checking every thing. For example do you know what resistance your air filter is causing? Testing such parts is normally done in top end motorsport using a variety of techniques. A magnehelic pressure differential guage is a good and cheap way to start (I am currently looking for one to come up on eBay ATM).
HPH.
BTW, have you driven it yet. Id be keen to hear what you think and keener still for a psx ride one day
Posted 20 November 2011 - 06:16 PM
HPH.
not quite right power has nothing to do with volumetric flow (l/min)it's mass flow (kg/min) the general equation for pressure loss = k * density * velocity^2 where k is factor based on the flow route. So unless you up the rev limit then all your changing incressing the boost is density. Where volumetric flow does come in is when you increase the rev limit which in turn increases the loss with a squared relationship so increasing the rev limit 10% will increase the loss through the intake by 21%
As stated above the inlet manifold is working well above it's design and restricting anything over 7krpm
Edited by Nev, 20 November 2011 - 06:17 PM.
