Ecu Change
#561
Posted 21 November 2011 - 01:00 PM
#562
Posted 21 November 2011 - 09:27 PM
#563
Posted 23 November 2011 - 03:00 PM
Edited by NickB777, 23 November 2011 - 03:03 PM.
#564
Posted 23 November 2011 - 04:25 PM
#565
Posted 23 November 2011 - 04:33 PM
You can get a company like Pro-Alloy (or other lesser known fabricators) to use your existing manifold to make a better one BTW. It's not really rocket science, just basic rules of thumb will improve the flow considerably.
If you read my blog, I did a experiment to look into this which explains it better.
Actually working gas dynamics is pretty close to rocket science
#566
Posted 23 November 2011 - 05:04 PM
I accept you could apply rocket science to it, but a simple 1 hour redesign (a la David Vizzard) would likely yield 80% of the improvement that 100 hours of detailed theoretical/experimental gas flow analysis would. I was trying to give a practical solution to Nick that he could actually achieve, rather than descend into idiology just for the sake of it.
Edited by Nev, 23 November 2011 - 05:08 PM.
#567
Posted 23 November 2011 - 05:07 PM
#568
Posted 23 November 2011 - 05:11 PM
#569
Posted 23 November 2011 - 05:34 PM
Edited by Nev, 23 November 2011 - 05:46 PM.
#570
Posted 23 November 2011 - 05:56 PM
Klassen Engine #1
Nipper #2
#571
Posted 23 November 2011 - 05:58 PM
you got a spare hour nev?
Yes, I'm bored to death without a car that needs fiddling with - why, whats your idea ?
#572
Posted 23 November 2011 - 06:07 PM
#573
Posted 23 November 2011 - 06:31 PM
Thus I would imagine you need:
1/ A supercharger that is physically distinct from the manifold with normal round inlet and outlet pipes.
2/ A remote and bespoke CC matrix (like the Pro-Alloy one for VXTs). The outlet from the supercharger would pipe to this.
3/ A brand new bespoke inlet manifold that is fed boosted air from the CC matrix.
All this would be quite expensive I imagine and would require a (rich) 'test dummy' for R&D... Ultimately (and as you know I'm not a S/C basher at all) you are chasing a lost cause due to the inhierent diminishing efficiencies of supercharging in comparison to turbocharging. I think Nick and Joe are already knocking on that door at 380 BHP. Getting 190% VE out of a SC'ed small engine is pretty good really, hats off to you. American V8 superchargers rarely even achieve 150% VE before they switch to turbos from what I've seen (look at the highly respected top-end Nelson engines to see what I mean).
TBH, 380 BHP and the super smooth delivery of torque in your cars will make them top dog on small to mid sized tracks, so I don't personally think you need to chase any more power as track cars. I think the only time you'd lose your podium spots are on big tracks or road circuits like the Nurburgring where power is dominant.
Edited by Nev, 23 November 2011 - 06:39 PM.
#574
Posted 23 November 2011 - 11:58 PM
The above is actually pretty simple:
- Buy Rotrex supercharger and mount in AC pump location. (C30-94 should do nicely I think)
- Fit the aluminium Saab B207 manifold. (maybe mod the TB pattern)
- Make a bespoke chargecooler in between and some plumbing skills needed.
Done.
Needs some bespoke mapping, but pretty doable and this should make awesome power up top. (And less weight too!)
But that's probably not what the majority want (proper mapping is a problem) and not sure if I will like the torque delivery of a centrifugal SC.
(But the above combo was and still is lurking in my back mind, especially as I am now able to properly map the VE table in my LSJ ecu.
Edited by Exmantaa, 23 November 2011 - 11:59 PM.
#575
Posted 24 November 2011 - 12:36 AM
#576
Posted 24 November 2011 - 09:47 AM
#577
Posted 25 November 2011 - 11:36 PM
Here is a good read http://www.hotrod.com/techarticles/engine/hrdp_0907_gm_ecotec_bolt_ons/viewall.html
I changed my 3"(80mm) to a 2.8" pulley when I reinstalled everything (forgot to Tell Courtenay’s though) I think that may have been a bad choice, all it does is heat the air up, when I have been running for a while to make certain there are no problems I will drop to the 2.9 and see if that makes a difference to the temps
A radical redesign of the intake manifold is needed it seems
#578
Posted 25 November 2011 - 11:38 PM
Doing a bit of reserarch
Only an hour job for Nev
#579
Posted 25 November 2011 - 11:42 PM
Edited by NickB777, 25 November 2011 - 11:42 PM.
#580
Posted 25 November 2011 - 11:45 PM
