Ecu Change
#41
Posted 30 April 2011 - 07:36 PM
#42
Posted 01 May 2011 - 12:03 PM
might pop over and swap those cams tomorrow afternoon if you are about
I had a go at getting that broken stud out and won't come out, in fact I think the drill bit went off centre
#43
Posted 01 May 2011 - 02:51 PM
#44
Posted 01 May 2011 - 06:30 PM
#45
Posted 01 May 2011 - 06:59 PM
I re-tapped a number of manifold holes to m8, terrifying
years since I have tapped heads, it's on, needs tightening tomorrow, Also looking for a z20let knock sensor to install. trying to figure a way to get these pesky s/c bolts back on, maybe get the dremel out to the rear bulkhead tomorrow.
Loosen the rear mount and tip the engine over. May give you a bit more room to reach those SC bolts.
Which bolts broke from the manifold? Hear that now a few times, despite fitted lower mount....
Edited by Exmantaa, 01 May 2011 - 07:01 PM.
#46
Posted 01 May 2011 - 07:20 PM
Edited by NickB777, 01 May 2011 - 07:21 PM.
#47
Posted 02 May 2011 - 11:58 AM
#48
Posted 02 May 2011 - 02:38 PM
Edited by NickB777, 02 May 2011 - 02:38 PM.
#49
Posted 02 May 2011 - 02:43 PM
Edited by joe_589, 02 May 2011 - 02:44 PM.
#50
Posted 02 May 2011 - 02:46 PM
90541521 SENSOR,KNOCKING LIMIT, CYLINDER BLOCKdont suppose you have a part number do you?
#51
Posted 02 May 2011 - 02:52 PM
#52
Posted 02 May 2011 - 03:38 PM
Edited by NickB777, 02 May 2011 - 03:50 PM.
#53
Posted 02 May 2011 - 03:56 PM
#54
Posted 02 May 2011 - 04:31 PM
you must be going he man on them?!
m8s on my head
think it's essential really, neeed to adjust the position of the map as the new one is bigger the the old and wont sit correctly UNDER the harrop
#55
Posted 02 May 2011 - 05:15 PM
#56
Posted 02 May 2011 - 05:30 PM
#57
Posted 02 May 2011 - 07:05 PM
Edited by NickB777, 02 May 2011 - 07:05 PM.
#58
Posted 02 May 2011 - 07:08 PM
#59
Posted 02 May 2011 - 07:18 PM
#60
Posted 02 May 2011 - 07:20 PM
