Ecu Change
1497 replies to this topic
#681 techieboy
Posted 26 June 2012 - 01:21 PM
it should do as the other tubby ecu harrop stage is emant to be running sweet..
Actually only 94% sweet.
#682 FLD
Might hang on to mine a bit longer then :unsure:
#683 The Batman
Posted 26 June 2012 - 01:24 PM
:lol: really? they need a group meeting everyday as it seems to change depending on who you speak to :lol:
#684 Rosssco
Rosssco
  • 4,183 posts
Posted 26 June 2012 - 01:32 PM
Without going through the whole thread, can I summarise the aim of this phase of NickB777's project is to get a OEM ECU to work on a Z22SE SC, allowing a more precise engine map, to get rid of the sometimes poor response, overfueling and somewhat lumpiness (couldn't think of a better word!) that seems to affect the tweeked NA ECU..?
#685 CocoPops
CocoPops
  • 17,181 posts
Posted 26 June 2012 - 01:33 PM
No.... Nick is running a Harrop rather than a M62 like the other stage 1/2 cars.
#686 The Batman
Posted 26 June 2012 - 01:35 PM
and the z22 cant be tweeked in the uk to run a high powered harrop conversion and as the z20 is there favourite ecu it was planned to run and use this ecu
#687 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 26 June 2012 - 02:04 PM
As Joe said this SHOULD allow me to run the z20let ecu on the z22se engine running a Harrop s/c which it is not possible to map properly (over 320bhp with S/C cams in) using the z22se ecu as it is still partially locked, the z20let ecu is open to all. The problem with it is the fact the z20let ecu was designed for a turbo application which has meant considerable rewriting of the software that Klassen has done. Also allowing me to keep most things oem if I had not knackered my scanguage I could use that also. 94% because the other harrop test car, had a cat failure which caused more problems won't mention hows it was but not one of Jims Joe will be running a LSJ ( with after market software) ecu and a third party will be running a DTA (with FBW TB) which ever does best (cost also involved) will became the high powered ecu of choice IMHO
Edited by NickB777, 26 June 2012 - 02:06 PM.
#688 The Batman
Posted 26 June 2012 - 02:06 PM
Who is running a dta?
#689 NickB787
NickB787
  • 7,813 posts
Posted 26 June 2012 - 02:08 PM
Rik on the z22 site although at the moment he is mapping for blower cams, low comp pistons, m62, ported head act. so will be interesting how the DTA performs compared to the z22se unit
Edited by NickB777, 26 June 2012 - 02:12 PM.
#690 The Batman
Posted 26 June 2012 - 02:14 PM
did he bin of the megasquirt in the end then?
#691 techieboy
Posted 26 June 2012 - 02:16 PM
Have DTA finally released the drive-by-wire module then? Or is it still a piece of vapourware?
#692 NickB787
NickB787
  • 7,813 posts
Posted 26 June 2012 - 02:18 PM
Yep that went some time ago he has had a couple of places do the mapping there is one place not far from Bedford which does DTA s/c mini's
Yet he has one cost a bit though but that was/is my next option it just connects directly to the DTA ecu there is a vx220 running one in Taiwan already
Edited by NickB777, 26 June 2012 - 02:20 PM.
#693 The Batman
Posted 26 June 2012 - 02:19 PM
thats another plus there is a place 15mins from me that does mapping for my ecu :tt:
#694 NickB787
NickB787
  • 7,813 posts
Posted 26 June 2012 - 02:25 PM
That is a BIG factor now
#695 Exmantaa
Posted 26 June 2012 - 04:01 PM
Great, this Harrop stuff is turning into an ecu-tuning race and it will be a close finish between the 2. :happy:
But in the end both should give the same results. (Although Joe should have a bit more headroom with his head, cams and injectors...)
#696 The Batman
Posted 26 June 2012 - 04:02 PM
:tt:
#697 vocky
Posted 26 June 2012 - 04:04 PM
The Saab under piston oil jets might make a difference ;)
#698 The Batman
Posted 26 June 2012 - 04:05 PM
and a few other tweeks :ninja:
#699 vocky
Posted 26 June 2012 - 04:06 PM
:ninja:
#700 The Batman
Posted 26 June 2012 - 04:07 PM
:yeahthat:
