Ecu Change
#741
Posted 28 June 2012 - 05:25 PM
#742
Posted 28 June 2012 - 07:54 PM
#743
Posted 28 June 2012 - 08:04 PM
Safe and drivable for the national and le mans then
lemans yes National no I had to cancel some time ago as I couldn't guaranty being ready in time.
#744
Posted 28 June 2012 - 08:18 PM
#745
Posted 28 June 2012 - 08:22 PM
#746
Posted 28 June 2012 - 08:29 PM
there are a few things which need adjusting one is a lag between lifting off and revs dropping from full throttle( changing gear)
Hum...
What is your DBW throttle body exactly ?
(sounds very very much like a DBW PID algorithm issue, which can be VERY dangerous)
#747
Posted 28 June 2012 - 08:35 PM
Edited by NickB777, 28 June 2012 - 08:38 PM.
#748
Posted 30 June 2012 - 06:02 AM
#749
Posted 30 June 2012 - 08:08 AM
#750
Posted 30 June 2012 - 08:19 AM
Edited by Nev, 30 June 2012 - 08:20 AM.
#751
Posted 30 June 2012 - 06:20 PM
#752
Posted 30 June 2012 - 08:22 PM
#753
Posted 30 June 2012 - 08:42 PM
What TB are you using Nev?. I reason I was going to give another TB a try was just to see if the slight problem with lag when lifting off is partly due to the Porsche TB itself or as alanoo had mentioned about a possible "DBW PID algorithm issue"
Are you 100% sure both OE and your TB are from the same brand ? (I think it's Bosch or Siemens on the Z20LET ?)
#754
Posted 30 June 2012 - 08:43 PM
#755
Posted 30 June 2012 - 09:31 PM
#756
Posted 30 June 2012 - 10:10 PM
#757
Posted 01 July 2012 - 11:57 AM
#758
Posted 01 July 2012 - 11:58 AM
#759
Posted 01 July 2012 - 06:44 PM
#760
Posted 01 July 2012 - 09:57 PM
