Ecu Change
1497 replies to this topic
#841 Rosssco
Rosssco
  • 4,183 posts
Posted 10 October 2012 - 06:24 PM
Great result Nick. Now leave it alone and drive it! thumbsup :)
:yeahthat:
:yeahthat:
:yeahthat:
#842 ultimate
ultimate
  • 261 posts
Posted 31 October 2012 - 04:33 PM
Wich cams are u running ?
#843 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 31 October 2012 - 05:58 PM
comp s/c cams in an oem head, need to port my saab one to get the zzp s/c cams in
#844 ultimate
ultimate
  • 261 posts
Posted 31 October 2012 - 06:04 PM
Thanks ;-) don't the zzp cams fit in the standard saab head? I thought they were designed for the LSJ=B207 Head?
Edited by ultimate, 31 October 2012 - 06:06 PM.
#845 NickB787
NickB787
  • 7,813 posts
Posted 31 October 2012 - 06:18 PM
:D yes thats why I am about to port my Saab b207 head which is sat here
#846 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 31 October 2012 - 06:21 PM
I will be interested to see what difference the ZZP cams make, I already have a saab head on mine with the comp cams blower cams.
#847 NickB787
NickB787
  • 7,813 posts
Posted 31 October 2012 - 06:25 PM
thats one reason I am loooking forward to Joe getting his running
#848 Exmantaa
Posted 31 October 2012 - 11:32 PM
We're all waiting on Joe-OEM... :happy:
Did you compare the specs between ZZP st2 and the Comp SC cams?
Stock LSJ is 196.5/191.7 duration @ 1mm(.039") valve lift and 10.04mm/10.04mm total valve lift. LSA is 107.5
ZZP S2 is 216/218 @ 1mm and 10.78mm/10.69mm lift, 111 LSA
Comp 2.2 SC cams:
  • Intake Duration at 050 inch Lift: 210 (= 1.27mm lift)
  • Exhaust Duration at 050 inch Lift: 218
  • Advertised Intake Duration: 252
  • Advertised Exhaust Duration: 262
  • Intake Valve Lift with Factory Rocker Arm Ratio: 0.423 in. (10.74mm)
  • Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.436 in. (11.07mm)
  • Lobe Separation (degrees): 113 LSA
Looks like the Comp 2.2 SC cams are even more aggressive than the ZZP stage 2's, but the different duration lift makes it harder to compare directly. :sleep:
Edited by Exmantaa, 31 October 2012 - 11:33 PM.
#849 ultimate
ultimate
  • 261 posts
Posted 31 October 2012 - 11:37 PM
Another important Question for me: Does that harrop scream so wonderful like the m62?
#850 techieboy
Posted 31 October 2012 - 11:47 PM
No, it's very very quiet.
#851 JG
JG
  • 13,612 posts
Posted 01 November 2012 - 08:12 AM
and thats a good thing thumbsup
#852 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 01 November 2012 - 08:42 AM
Are all you boys upgrading the valves and springs in the head? Something like superteck, or is it not worth it.
#853 smiley
Posted 01 November 2012 - 09:01 AM
I love the m62 screaming on track. Drive it normal and you hardly hear it.
#854 NickB787
NickB787
  • 7,813 posts
Posted 11 June 2013 - 03:49 PM
I'll raise this again
I am now going ODB software the ecu is going to him. I am sending a new spare ecu and he will transfer the security information form my old ecu onto the new one. That way I will have the c`ms mapped ecu as a backup.
I have 630cc injectors, need to get some spacers  sorted. FLD gave me an oem FPR to replace the CMS modified unit.
3 and 2.5 bar TMAP sensors available to me.
I have ordered a WI kit to try to keep the temps down. I will try mapping with a 2.7" pulley.
Edited by NickB777, 11 June 2013 - 03:51 PM.
#855 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 11 June 2013 - 06:32 PM
Nick what head work and valves do you have while we are reviving this thread? A So what rev range will you be setting the car at?
#856 CocoPops
CocoPops
  • 17,182 posts
Posted 11 June 2013 - 06:36 PM
Interesting.... So you could literally unplug one ecu and plug the other one in and everything works? thumbsup
#857 smiley
Posted 11 June 2013 - 07:02 PM
Yes, i did the same.
I now have one with a CMS basemap and one with obdtuner on it.
#858 NickB787
NickB787
  • 7,813 posts
Posted 11 June 2013 - 07:13 PM
I have a z22se ported head with Saab turbo (sodium filled) valves due to the heat and double valve springs could rev till 8000+ but won't will set at say 7500 depends on what psi I get and how much heat is generated.
Yea I can keep the old cms ecu as a backup just in case.
#859 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 11 June 2013 - 07:19 PM
Cheers
#860 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 11 June 2013 - 08:15 PM
Just wondering if you know where these spacers can be bought from or what do they look like?
    Google (1)
