Ecu Change
1497 replies to this topic
#861 Exmantaa
Posted 11 June 2013 - 09:52 PM
  I am now going ODB software the ecu is going to him. I am sending a new spare ecu and he will transfer the security information form my old ecu onto the new one. That way I will have the c`ms mapped ecu as a backup.
Interesting.... So you could literally unplug one ecu and plug the other one in and everything works? thumbsup
That only works if you have them mapped for the same injectors and/or MAP sensor. But those are easy to change too if needed.
To the spacers/isolators; these are standard on the Saab or US LSJ engine, but then also the fuel rail is raised with some spacer blocks. You don't need these and several SC-ed Speedsters have LSJ injectors directly fitted on a Z22SE (or Saab) head. 60lbs have the same length.
#862 rik
rik
  • 2,187 posts
Posted 11 June 2013 - 10:31 PM
I might still have the spacers that I removed from my saab head if you can't find them new elsewhere?
#863 Exmantaa
Posted 11 June 2013 - 10:34 PM
As said, you also need fuelrail raiser blocks to go with the injector spacers...
#864 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 12 June 2013 - 08:32 AM
Ah I take it they are difference sizes?,  Better check my saab bits in the shed. then better check for the same bits in techieboys shed :D
I have a saab parts shop very near me wonder If I can get theses from them, I have some injector spacers coming.
#865 Exmantaa
Posted 12 June 2013 - 08:52 AM
You can see the 2 alu raiser blocks on the fuel rail here: http://www.ebay.co.u...36#ht_569wt_838
#866 rik
rik
  • 2,187 posts
Posted 12 June 2013 - 10:02 PM
so close.. (missing the other metal bit)
#867 NickB787
NickB787
  • 7,813 posts
Posted 13 June 2013 - 07:03 AM
I think I see what you meant Exmanta I will need the fuel rail blocks/spacer but don't need the injector spacers with the siemens 60lbs as they are longer anyway?
Edited by NickB777, 13 June 2013 - 07:11 AM.
#868 Exmantaa
Posted 13 June 2013 - 07:17 AM
No,
Same length so the 60's fit directly. Only if you want to fit them with those spacers/isolators, you also need the fuelrail raiser blocks.
#869 siztenboots
Posted 13 June 2013 - 07:27 AM
For me it only takes 10 mins to backup the ECU and download a new file to it , with the immo data transfered across. So I only have a second ECU for doing benchwork testing as its a lot easier to work indoors warm and comfortable at a desk , rather than relying on battery power having the ignition on and the laptop battery.
#870 NickB787
NickB787
  • 7,813 posts
Posted 13 June 2013 - 08:02 AM
No,
:lol:  I just checked strange because I ordered 60lbs LONG I automatically thought spacer required. I just checked and they are exactly the same as the vxr ones :beat: idiot
The backup one with cms map I could alway revert to the same setup I have now but in reality too much hassle
Which software are you using Steve?
#871 siztenboots
Posted 13 June 2013 - 08:09 AM
galleto
#872 oakmere
oakmere
  • 2,143 posts
Posted 13 June 2013 - 08:45 AM
OBD takes about 30 seconds to program the ECU and 5 seconds to save a map to the pc. So no need to worry about batteries. Most changes whilst playing with the map can be done live so are instant. Changes then have to be programmed to the ECU to make permanent.
#873 siztenboots
Posted 13 June 2013 - 09:26 AM
its about 5 mins to program the whole ecu, firmware and map from blank. To just fiddle about with map entries its as you say instantaneous. The hardest part about live mapping it is cleaning up the spurious data.
#874 NickB787
NickB787
  • 7,813 posts
Posted 23 June 2013 - 05:55 AM
Ecu s on its way back, JUST got to put the car back together now and just in capitals is an understatement, Techieboy can tell you.
#875 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 24 June 2013 - 01:23 PM
Good luck Nick, don't forget to order the ecu to pc cable :)
#876 NickB787
NickB787
  • 7,813 posts
Posted 27 June 2013 - 12:49 PM
Well got cracking on with it, loads of stuff to do, one I wanted to check since I removed the clam was to give the exhaust the once over. I had problems with the mot emissions. So off with the CAT great job  :angry2:
Good news was that there is still a CAT there I called Jim to tell him and while speaking I looked again and noticed some lines down the inside of the CAT pipe, turned the pipe over and you could hear the CAT sliding inside the pipework,DEAD :(
New one required, Jim was great about it. Am sending it ASAP at least I can start mapping when it comes back with a new
#877 oakmere
oakmere
  • 2,143 posts
Posted 27 June 2013 - 04:43 PM
Nick When you start mapping just cover normal driving to start with and this will give you an idea of what to expect and how to apply the changes to the map. Also you will be able to see how far out the base map is out by the fuel changes made. Will you be using the wideband mapping for WOT?
#878 NickB787
NickB787
  • 7,813 posts
Posted 27 June 2013 - 08:53 PM
Will do I when I start mapping I will take it nice and easy, no rushing and I will be asking lots of questions....
I have asked Jim to put in an extra hole for the wideband so I will use that I think as it seems probably best.
One interesting thing I noted when I removed my plugs ITV24's yesterday was that they are black, been running rich or what..
Edited by NickB777, 27 June 2013 - 08:54 PM.
#879 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 27 June 2013 - 09:38 PM
Looking forward to seeing the results and i will be following shortly after you.  Im in the same boat as you mate with my cat but mine has shot it out. Im going have to get another one made so when you say extra hole for the wideband is that just on the cat pipe. I thought the wideband goes into the lambda sensor hole?
#880 smiley
Posted 27 June 2013 - 10:18 PM
Wideband is an extra sensor, not a replacement.
