Ecu Change
#901
Posted 10 July 2013 - 06:07 PM
#902
Posted 10 July 2013 - 06:08 PM
I might just be
#903
Posted 10 July 2013 - 06:09 PM
#904
Posted 10 July 2013 - 06:11 PM
Have you used the program yet nick,
if you want im not at work tomorrow i will give you my number and you can call me if you have any problems,
im also mapping again tomorrow
#905
Posted 10 July 2013 - 06:16 PM
Great please PM your number, I have a few (read Flipping loads) of stuff to put in the cabin first thing but intend to start her up late morning/early afternoon. I am high speed broadband here could skype real time.
#906
Posted 10 July 2013 - 06:18 PM
PMed
#907
Posted 11 July 2013 - 11:26 AM
She is running, really pleased.
I Spoke will Chill for advice before turning it on, Techieboy (many Thanks to both of you) was good enough to come over as tech adviser in case nothing happened, and nothing happened initially till I plugged the fuel pump back in. Just realised as I write this only hope I haven't stuffed the CC pump running without water ops.
Did some initial logging to make certain it works, she seems to idle smother on the 630cc injectors.
I will now clean some of the wiring harness up, rebuild the inside and get ready for the clam going back on tomorrow. The got to fill her up and start mapping
#908
Posted 11 July 2013 - 11:28 AM
#909
Posted 11 July 2013 - 11:29 AM
#910
Posted 11 July 2013 - 11:37 AM
awesome
It would be great to hear what your find for a more subjective point of view between the CMS and the OBD maps you will create.
If you are not running anything through the EGR valve at the moment, still put some values in, otherwise it corrups the learning map you make (bug in the software that is getting fixed).
#911
Posted 11 July 2013 - 11:47 AM
Cheers Dave I have put some values in for the PLX wideband, although it is not set up yet
#912
Posted 11 July 2013 - 12:00 PM
#913
Posted 11 July 2013 - 12:41 PM
#914
Posted 11 July 2013 - 12:44 PM
The idle was the first thing I noticed
#915
Posted 11 July 2013 - 12:46 PM
#916
Posted 11 July 2013 - 12:48 PM
what were they
#917
Posted 11 July 2013 - 01:17 PM
idle is good on mine too with blower cams on base map (idle is as far as I have gotten so far )
#918
Posted 11 July 2013 - 08:17 PM
well done Rik,
#919
Posted 13 July 2013 - 02:04 PM
Well a really productive day, Techieboy was kind enough to come over this morning to help crack on with it . We rebuilt the interior, that was fun mainly because that was my storage area for parts when I had the car stripped. Forgot how to rewire the extra gauges I have, little job on the internet later. Wired in the wideband sensor in, Water injection was left till later.
Apart from the odd extra pipework left (fuel canister) over it's nearly finished. MMG diffuser to go on, most things are now done, almost ready for next weekend.
Did an initial run to see how the ecu self learns, thanks to Chill being on the end of a phone to run use through it. Nice to see it doing its thing rather than just reading about it.
#920
Posted 13 July 2013 - 02:39 PM
My pleasure. Somebody has to maintain the Bedford Europa Blue SC society presence at the National, this year, and it's not going to be me. Just glad it all went back together as well as it did, though there was an alarmingly large number of left over nuts/bolts/screws at the end.
Will look forward to seeing what Monday's learning session brings.
Google (1)
