Ecu Change
1497 replies to this topic
#921 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 15 July 2013 - 02:19 PM
something is wrong here,  we had the car running ok, I went to start it this morning and a totally dead battery, I did some checking of the wiring I had done and realised I had connected my wideband Lambda to a permanently live feed not a ignition switched feed. I redid this correctly, while wating to charge the battery up again I wired in the WI system.
I went to start it and had a constant EML light up. I now seem not to be able to get an intake air temp plus it's not checking lambdas, anyone any ideas, here are the logs.
#922 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 15 July 2013 - 02:30 PM
i have looked throught he text file and compared to mine. all looks very similar.
This sheet says you are getting no engine management error codes, but have you checked to make sure?
#923 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 15 July 2013 - 02:31 PM
Mine has an EML light because I have no 2nd lambda.
#924 NickB787
NickB787
  • 7,813 posts
Posted 15 July 2013 - 02:57 PM
i  seem to have goy my IAT back, I had a transient p0141 code. will do some more checking
#925 CHILL Gone DUTCH
Posted 15 July 2013 - 02:58 PM
Check second lambda plug nick
#926 CHILL Gone DUTCH
Posted 15 July 2013 - 03:08 PM
and ive just checked your your duty cycle of the injectors and there only at 5% from the logging session above, did you go anywhere. lol
#927 oakmere
oakmere
  • 2,143 posts
Posted 15 July 2013 - 03:09 PM
I would also say a wiring problem with the lambda sensors.
#928 CHILL Gone DUTCH
Posted 15 July 2013 - 03:11 PM
When you get chance nick can you post your base map file so i can see if there is anything there
#929 FLD
Posted 15 July 2013 - 03:15 PM
Can you not 'switch off' the second lambda in the software?  One less thing to stress over.
#930 oakmere
oakmere
  • 2,143 posts
Posted 15 July 2013 - 03:18 PM
I don't think so. All you can turn off is the cat efficiency check so you can remove the cat. It users the second sensor as a safety check in case lambda 1 fails when logging learning the fuel map.
#931 CHILL Gone DUTCH
Posted 15 July 2013 - 03:21 PM
i asked peter that, the answer is no because
[color=rgb(31,73,125);font-family:Calibri, sans-serif;font-size:15px;] The ECU is still using the second lambda as a backup to the main lambda sensor. So the second lambda is still used to check if your engine is running lean etc. So when you switch of the cat check in ObdTuner  the ECU will not use the second lambda for checking on the cat, but all the other checks remain working.[/color]
Edited by CHILL Gone DUTCH, 15 July 2013 - 03:22 PM.
#932 rik
rik
  • 2,187 posts
Posted 15 July 2013 - 03:24 PM
interesting.. I didnt realise that - thought it was disabled completely by that option in the software
I think I had this too, second lambda is not hooked up at all (but can be I suppose)
#933 CHILL Gone DUTCH
Posted 15 July 2013 - 03:46 PM
Nick dont do a learn session with a code, (PID)
Edited by CHILL Gone DUTCH, 15 July 2013 - 03:49 PM.
#934 NickB787
NickB787
  • 7,813 posts
Posted 15 July 2013 - 04:11 PM
ok no code at the moment still putting the car together, I have just found in the shed the thermal bit which goes under the clam :( above the back box, do I need it, clam off again to fit it :(  :(
no didn't go anywhere just idle at home
Edited by NickB777, 15 July 2013 - 04:12 PM.
#935 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 15 July 2013 - 04:21 PM
I dont think the software will let you map with an error code in place.
I hadnt run a second lambda for a while, the CMS map disables it. But i need to put one back in for the OBD tuner software. I think I mentioned this before. You could put a cheater in, but you are only cheating yourself, so to speak.
#936 CHILL Gone DUTCH
Posted 15 July 2013 - 04:23 PM
I dont think the software will let you map with an error code in place.   I hadnt run a second lambda for a while, the CMS map disables it. But i need to put one back in for the OBD tuner software. I think I mentioned this before. You could put a cheater in, but you are only cheating yourself, so to speak.
And cheating the software which you don't want to do when mapping
#937 rik
rik
  • 2,187 posts
Posted 15 July 2013 - 08:47 PM
glad I'm not the only one - I do this every time without fail :beat:
#938 smiley
Posted 15 July 2013 - 09:56 PM
I thouht the isolation was ducktaped to the clam by oem?
#939 NickB787
NickB787
  • 7,813 posts
Posted 16 July 2013 - 07:32 AM
not on mine but next time it comes off it will be have a layer of duct tape over it, "horse/ door" :rolleyes:
right back to work.
Edited by NickB777, 16 July 2013 - 07:32 AM.
#940 siztenboots
Posted 16 July 2013 - 07:43 AM
I don't have the thermal bit ( looks like some cruddy old fiber board ) on mine.
