Ecu Change
#1001
Posted 17 July 2013 - 12:25 PM
#1002
Posted 17 July 2013 - 12:28 PM
here was the last log I did
#1003
Posted 17 July 2013 - 12:29 PM
I didn't think the base map is anywhere near a 14.7:1 commanded AFR though. Thought it was set to 11.8:1 commanded on basically anything like WOT.
#1004
Posted 17 July 2013 - 12:37 PM
I have noticed that the weather plays a big part in what the fuel trims are. This could be improved by altering the transient settings in the OBD software. With air intake temp currently around 40-45 degrees C the long term fuel trims are running at about -4 for idle and normal driving. That is approx -2% fuel.
Haha, I spend weeks trying to get all the fueltrims to 0.0% with my LSJ ecu, but the wheater will always influence it and everyday is a bit diifferent. So I gave up and <1.5% will do for me. (And that's why the fueltrims are there...)
Especially the low load, idle & decelleration is difficult, as there the non linear injector flowrate plays a big part. If your injector settings are not spot-on, you will never get this area 100% right. (and every injector has manufacturing tolerances...)
#1005
Posted 17 July 2013 - 12:41 PM
#1006
Posted 17 July 2013 - 12:47 PM
#1007
Posted 17 July 2013 - 12:49 PM
When you are running a fuel learn it is locked to 14.7:1 AFR.
#1008
Posted 17 July 2013 - 12:53 PM
#1009
Posted 17 July 2013 - 12:57 PM
Exmantaa I know that the wideband dose not live map like the narrow band but I don't recommend Nick runs the car a 14.7:1 ratio for WOT runs with our current weather conditions. I would look at the modifications made by the software at lower RPM's to see if the supplied base map looks good,or send this info to Peter. Nick do you have a screen save of any fuel learn measurements?
Your correct and I definately don't recommend doing WOT runs in the closed loop 14.7 learing mode on a high boosted car!! That you do only for low/mild cruising loads.
#1010
Posted 17 July 2013 - 01:07 PM
I will keep loads down nice cruise to pembrey, Just wish there was an easy way to check the wideband is working correctly.
#1011
Posted 17 July 2013 - 01:08 PM
before a Finnish work today.
#1012
Posted 17 July 2013 - 01:18 PM
Nick I will take a look at the results before a Finnish work today.
Thank you
#1013
Posted 17 July 2013 - 01:32 PM
Edited by oakmere, 17 July 2013 - 01:35 PM.
#1014
Posted 17 July 2013 - 01:55 PM
nick have you gone back to the base map
yesterday you put a learned map into the ECU permanent memory
#1015
Posted 17 July 2013 - 02:21 PM
the "first learn" map was the one I did yesterday, which is removing fuel from Peters base map,
I uploaded the base map to the ecu again this morning as I am learning how to do things. I was thinking of just going for another learn session but the conditions are the same as yesterday, HOT so don't think there is any reason too. I may reload the leaned map from yesterday and try a drive today I really want to confirm the wideband is working before I do any WOT runs
#1016
Posted 17 July 2013 - 02:35 PM
Just putting ideas out there
if you no the base map is rich which it appears to be knocking fuel of in the learn session you have done, why dont you do a power measurement on the base map and physically see if the Wideband is working from the AFR results.
that is why i was trying to get you to do a power measurement on the base map on the first day. to check the wideband.
i have to be honest i did assume the base map was rich (safe)
#1017
Posted 17 July 2013 - 02:44 PM
Why not use the OEM ECU to operate the electronic throttle and piggyback an additional position sensor to feed a 3rd party ECU?
#1018
Posted 17 July 2013 - 02:58 PM
#1019
Posted 17 July 2013 - 03:02 PM
What for?Why not use the OEM ECU to operate the electronic throttle and piggyback an additional position sensor to feed a 3rd party ECU?
#1020
Posted 17 July 2013 - 03:20 PM
Cheap and saves dumping the pedal!
