that will be great if it's working ok. because of the heat I have decided to wake the locals up at 0early oclock tomorrow
Ecu Change
#1041
Posted 17 July 2013 - 04:23 PM
#1042
Posted 17 July 2013 - 04:26 PM
Go and nick Lee's AFR gauge and hook it up to the wideband controller to see what, if anything, it's doing.
#1044
Posted 17 July 2013 - 04:29 PM
#1045
Posted 17 July 2013 - 04:34 PM
Did you start logging twice there seems to be a bit of interference to
#1046
Posted 17 July 2013 - 04:59 PM
Just started up my copy of OBD tuner and loaded Nicks calibration. (1st time I play with a real calibration in it. :-) )
You can log Target AFR together with your measured AFR to see what is what. Only the decelleration fuel cut-off will not show in the target AFR, so drive smooth and decellerate with the clutch in to get a good AFR log.
What wideband is fitted? You probably need to tweak the EGR>AFR conversion formula a bit to get it spot on. (it's an analog voltage signal so any wiring signal/ground offset will influence your AFR reading.)
Edit: Why do I see those straight lines running through the graphs in the log? Looks like there are 2 logs together? (Sorry, I'm spoiled by my HPTuners scanner logs...)
Edited by Exmantaa, 17 July 2013 - 05:04 PM.
#1047
Posted 17 July 2013 - 05:09 PM
I am running a PLX the ground runs to the ecu, plx do sujest putting a capaciter between the signal and ground colase to the ecu
http://www.plxdevice...RUsersGuide.pdf Peter said he didn't think it would need it.
Driving it hooked up and logging is the only way to check really
#1048
Posted 17 July 2013 - 05:16 PM
No, I meant that ground offsets can influence your signal processing, but running the WB ground to the same the ecu ground point is good practice.
You simply need to check if it's measuring around 14.7AFR when running in Closed Loop and then maybe tweak the WB settings to get it spot on. (Will check that link)
Did you perform a free air calibration on the sensor?
Edit; cannot read it in the manual, but do you need to erase a log (in the ecu) before you start another? It really looks like 2 sessions together...
Edited by Exmantaa, 17 July 2013 - 05:20 PM.
#1049
Posted 17 July 2013 - 05:26 PM
no free air calibration, PLX was about the only one which didn't need it
will clear the logs
#1050
Posted 17 July 2013 - 05:41 PM
PLX looks pretty straight forward and the only way to check it is to simply drive in Closed Loop and log the AFR readings.
(Edit: best start a fresh log with a warm engine, so the fuelling does not get messed up with enrichment phases.)
Edited by Exmantaa, 17 July 2013 - 05:42 PM.
#1051
Posted 17 July 2013 - 05:58 PM
#1052
Posted 18 July 2013 - 07:57 AM
Ok did a power run, didn't go that well. I only did one as peak power was well down at 6400rpm then it was like hitting the limiter
#1053
Posted 18 July 2013 - 07:58 AM
#1054
Posted 18 July 2013 - 08:05 AM
nick you have a lot of knock
double click on the lines at bottom of page and hover over the lines,
peter only thinks 0.5 % of knock is acceptable
#1055
Posted 18 July 2013 - 08:08 AM
where has the logging session come from in this file ??
#1056
Posted 18 July 2013 - 08:10 AM
why dosent the power run start at 2000 RPM ?
did you put foot hard to the floor fromm 2000 RPM?
#1057
Posted 18 July 2013 - 08:18 AM
the car went lean at 6800 rpm,
looks like fuel starvation
#1058
Posted 18 July 2013 - 08:25 AM
not certain why it didn't record from 2000rpm
I did this on the map which I have updated from the learning process.
ignition was all over the place
I have an bosch 044 and swirl pot so shouldn't be fuel starvation.
#1059
Posted 18 July 2013 - 08:27 AM
can you do a logging session with a WOT run upto around 6800 rpm then we can see more information from logging might be able to pick up from that a problem.
#1060
Posted 18 July 2013 - 08:28 AM
I wonder if I go back to base map do a power run?
