put it back to base map and try again
Ecu Change
#1061
Posted 18 July 2013 - 08:29 AM
#1062
Posted 18 July 2013 - 08:30 AM
similar minds, lol
did you do a full learn session and get results in all boxes
#1063
I am charging the laptop at the moment, when complete I will take it the ipad so I can post here and will try a few things?
is it worth doing the ignition and processing AFR data into the ecu then try another run?
why knock and lean???
#1064
Posted 18 July 2013 - 08:32 AM
not all boxes this was where I finnished at
#1065
Posted 18 July 2013 - 08:37 AM
thats why we need reference, from base map,
lean could be because of not having all boxes filled or fuel starvation,
knock normally comes from ignition.
i would go to base map first do a power measurement and a short logging session then we have some references,
#1066
Posted 18 July 2013 - 08:38 AM
Nick did you "process measurement" the learn session to auto fill the boxes and smooth the fueling??
Edited by CHILL Gone DUTCH, 18 July 2013 - 08:40 AM.
#1067
Posted 18 July 2013 - 08:46 AM
Pretty certain I did
#1068
Posted 18 July 2013 - 08:48 AM
It takes around 3 minutes to do while car is runningPretty certain I didNick did you "process measurement" the learn session to auto fill the boxes and smooth the fueling??
#1069
Posted 18 July 2013 - 08:52 AM
#1070
Posted 18 July 2013 - 08:54 AM
nick i would go back to base map,
power measurement and power run,
then we can start modifying fueling and ignition
#1071
Posted 18 July 2013 - 09:35 AM
#1072
Posted 18 July 2013 - 09:42 AM
Edited by oakmere, 18 July 2013 - 09:46 AM.
#1073
Posted 18 July 2013 - 09:47 AM
i really think we should be starting from base map, to get good references to see if the wideband has good calibration and reference points.
the learn session nick was using was limit to a very small amount of data
and no data at higher pressure,
and if nick managed to process the measurement to autofill im not convinced there was enough data to do it,
comments martin would be good.
we are trying to run before we can crawl
#1074
Posted 18 July 2013 - 10:16 AM
#1075
Posted 18 July 2013 - 10:19 AM
what is your plan of attack nick
#1076
Posted 18 July 2013 - 10:40 AM
#1077
Posted 18 July 2013 - 12:34 PM
#1078
Edited by NickB777, 18 July 2013 - 12:36 PM.
#1079
Posted 18 July 2013 - 12:38 PM
we are trying,
was there a problem with base map
#1080
Posted 18 July 2013 - 12:40 PM
