Ecu Change
1497 replies to this topic
#1081 oakmere
oakmere
  • 2,143 posts
Posted 18 July 2013 - 02:06 PM
Nick You would not be happy if not breaking new ground. The logs on the power run file look fine no double trace. Also the actual AFR from the wide band follows the target AFR quite well so it would seem to be working. This is something I will be doing over winter I think. All the sensor reading seemed to be working. Are you still getting the lambda error code?
#1082 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 18 July 2013 - 02:18 PM
I can't stop can I I think Davemate should get a wide and in ASAP though
#1083 CHILL Gone DUTCH
Posted 18 July 2013 - 02:20 PM
I will be putting wide band in to after my Rods have been done so I can see what I can get out of this M62 charger with 3.1 pulley, I might even change pulley to
#1084 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 18 July 2013 - 02:29 PM
Weekend after next I am visiting my exhaust guy to get the bung welded in.
Peter mentioned that the LC1 type has proved to be the most relyable. Are you sure you have the right settings for your wideband?
#1085 oakmere
oakmere
  • 2,143 posts
Posted 18 July 2013 - 02:34 PM
Nick AFR readings look quite good on the logs from the wide band. But as Exmantaa said you should tweak the settings to give 14.7 AFR in closed loop running.
#1086 Rosssco
Rosssco
  • 4,183 posts
Posted 18 July 2013 - 02:36 PM
With regards the wideband sensor - do you just need the sensor, not the controller?
http://www.ebay.co.u...d8#ht_395wt_932
Edited by Rosssco, 18 July 2013 - 02:37 PM.
#1087 CHILL Gone DUTCH
Posted 18 July 2013 - 02:42 PM
I believe you just need the controller and sensor with Dutch Ecu and wire it into the old EGR valve wiring
Edited by CHILL Gone DUTCH, 18 July 2013 - 02:49 PM.
#1088 oakmere
oakmere
  • 2,143 posts
Posted 18 July 2013 - 02:48 PM
No you need a controller.
#1089 fezzasus
Posted 18 July 2013 - 02:49 PM
What pulley do you have? I have a bag of smaller pulleys
#1090 CHILL Gone DUTCH
Posted 18 July 2013 - 02:50 PM
It's a four stud one think its a GM one
#1091 oakmere
oakmere
  • 2,143 posts
Posted 18 July 2013 - 02:51 PM
See the spartan unit from this company:
http://www.14point7.com/
The software uses the analog voltage.
#1092 Rosssco
Rosssco
  • 4,183 posts
Posted 18 July 2013 - 02:56 PM
Any 3.1" pulleys?
#1093 Rosssco
Rosssco
  • 4,183 posts
Posted 18 July 2013 - 02:57 PM
Balls, more money!
#1094 CHILL Gone DUTCH
Posted 18 July 2013 - 03:01 PM
Would this do it Martin
Edited by CHILL Gone DUTCH, 18 July 2013 - 03:01 PM.
#1095 NickB787
NickB787
  • 7,813 posts
Posted 18 July 2013 - 03:33 PM
Yep nice to know the wideband is ok just waiting for the new map from Peter.
#1096 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 18 July 2013 - 04:08 PM
peter also reccomends a heatsync bung to stop it from getting toasted al the time. This is what I will be putting in mine.
#1097 CHILL Gone DUTCH
Posted 18 July 2013 - 04:20 PM
Have you got any logs or power measurements Dave I'm interested in a look
#1098 NickB787
NickB787
  • 7,813 posts
Posted 18 July 2013 - 04:48 PM
Just got the reply and file from Peter will get it on
#1099 oakmere
oakmere
  • 2,143 posts
Posted 18 July 2013 - 05:01 PM
Keep sending your data to Peter he will get you sorted quicker. I would get the new map on and try another power run to see how things look though I am sure peter is advising what to do.
#1100 oakmere
oakmere
  • 2,143 posts
Posted 18 July 2013 - 05:03 PM
What is a heat sink bung?
