Post cat lambda is dead i think. Mine changes voltage yours is static at 0.4 volts. Nick your intake temps are through the roof on the last two power runs? The first was much lower and power much higher.
Posted 18 July 2013 - 09:14 PM
Posted 19 July 2013 - 07:32 AM
Worth checking the chargecooling system (primarily the water pump) is still working.
Posted 19 July 2013 - 07:34 AM
0.4v for cat lambda is normal
Posted 19 July 2013 - 07:37 AM
May be my cat is on the way out?0.4v for cat lambda is normal
Posted 19 July 2013 - 07:39 AM
I thought this IAT 90+ degrees C somthing has got to be wrong!Worth checking the chargecooling system (primarily the water pump) is still working.
Posted 19 July 2013 - 08:25 AM
Posted 19 July 2013 - 08:30 AM
Is there anywhere to post longer logs on the forum? Nick's 2 short ones don't show very much... (besides 90*C intake temps? )
And do I see 6-7 degrees of KR in that power run? Please retard ignition a bit before you damage your pistons and start with a safe AFR...
(you can change the WOT target AFR's simply to 11.2 or so for the first WOT runs. You get more safety marging If the map is too lean. When you're getting near 11.2, simply change your target AFR back to what they were (11.8?) and continue fine tuning.)
Posted 19 July 2013 - 08:32 AM
yeo I did, I got a reply last night and he is worried about my IAT's
Posted 19 July 2013 - 08:41 AM
what the heck it wrong?
the cc pump is working, it never used to get above warm temps now it's hot I know we never used to have IAT post supercharger before but I can't figure it. I wonder what davemate is getting and what pulley he has on I am only on 2.9inch
Posted 19 July 2013 - 08:45 AM
I also think a 2.9 harrop pully on our stock M62 manifold is just to much.
Try a bigger one, if you can switch easily.
Posted 19 July 2013 - 08:50 AM
Check the basics, as the water temp in an SC-cc system never gets really "hot". And certainly not during normal road driving...
So first is your cc-system plumbed up ok? No mix-up witth car coolant tubes? it flows when pump is switched on and engine not running? (bridge your relay to check)
Then maybe check if your SC-bypass opens during idling etc, as a closed bypass valve may lead to increased IAT's.
My mate runs a 80mm pulley on his Harp to keep the IAT's under control, but still reaches 80+*C on hard tracking...
Posted 19 July 2013 - 08:52 AM
could you have the polarity wrong on the tmap sensor
Posted 19 July 2013 - 08:53 AM
how can I check the sc bypass is open? I might change to an 80mm pulleyCheck the basics, as the water temp in an SC-cc system never gets really "hot". And certainly not during normal road driving... So first is your cc-system plumbed up ok? No mix-up witth car coolant tubes? it flows when pump is switched on and engine not running? (bridge your relay to check) Then maybe check if your SC-bypass opens during idling etc, as a closed bypass valve may lead to increased IAT's. My mate runs a 80mm pulley on his Harp to keep the IAT's under control, but still reaches 80+*C on hard tracking...
Posted 19 July 2013 - 08:55 AM
Posted 19 July 2013 - 09:12 AM
Posted 19 July 2013 - 09:13 AM
bad earth , causing Vref to float ?
