Ecu Change
1497 replies to this topic
#1161 Exmantaa
Posted 21 July 2013 - 09:09 PM
How's the intake temp now?
#1162 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 21 July 2013 - 09:15 PM
much lower I am pleased to say.
#1163 oakmere
oakmere
  • 2,143 posts
Posted 22 July 2013 - 07:42 AM
Might be worth a plug change Nick if not been changed for a while. Look at the plug condition and coloration, as it may help identify any issues!
#1164 NickB787
NickB787
  • 7,813 posts
Posted 22 July 2013 - 08:16 AM
I'll get one ordered
#1165 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 22 July 2013 - 01:24 PM
if you are looking for trial and error swaps you are welcome to bits from mine :)
#1166 NickB787
NickB787
  • 7,813 posts
Posted 22 July 2013 - 01:30 PM
cheers Dave, I am having a day off but will try to get it sorted.
knock sensor change
change position of 044, mine is vertical next to the swirl pot, I never liked this position much will lay t flat.
change the 044 pump
change the in tank pump
sell car
after a lot of work today I finally got my old sony laptop using winxp and now can open Peters software, I was getting a few error messages with the macbook, when using win7. Just hope the sony will talk to the car.
Edited by NickB777, 22 July 2013 - 01:39 PM.
#1167 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 22 July 2013 - 01:40 PM
i wouldnt take the chance of a flakey laptop, if you were uploading it may cause a problem.
Borrw one if you can to be on the safe side.
#1168 NickB787
NickB787
  • 7,813 posts
Posted 22 July 2013 - 01:45 PM
its a vaio still a good machine just had to dump win7 which I put on it and revert to xp to get it to run at a sensible speed. problem is microsoft dont support xp now so have to go looking around the next for what I want.
#1169 CHILL Gone DUTCH
Posted 22 July 2013 - 01:50 PM
cheers Dave, I am having a day off but will try to get it sorted.    knock sensor change change position of 044, mine is vertical next to the swirl pot, I never liked this position much will lay t flat. change the 044 pump change the in tank pump Keep car and go tracking   after a lot of work today I finally got my old sony laptop using winxp and now can open Peters software, I was getting a few error messages with the macbook, when using win7. Just hope the sony will talk to the car.
Edited by CHILL Gone DUTCH, 22 July 2013 - 01:50 PM.
#1170 NickB787
NickB787
  • 7,813 posts
Posted 22 July 2013 - 01:53 PM
o and the JUST change the knock sensor is a pig of a job
#1171 NickB787
NickB787
  • 7,813 posts
Posted 22 July 2013 - 02:00 PM
Ouch £42 for a knock sensor
Edited by NickB777, 22 July 2013 - 02:13 PM.
#1172 NickB787
NickB787
  • 7,813 posts
Posted 22 July 2013 - 03:46 PM
is there a way to check the fuel pressure at high rpm's? I really want to see if the pump is loosing pressure or assuming it is constant  with no losse could it be a software issue
#1173 Nev
Posted 22 July 2013 - 04:33 PM
If you have a schraeder pressure release valve on the fuel rail, you can buy a cheap mechanical gauge and long pipe from eBay and keep it in the cabin as you drive.
#1174 Exmantaa
Posted 22 July 2013 - 10:54 PM
Measure FP on valve (or T-piece in feed hose) and measure return flow (volume/time) from the rail outlet tube @ atmo pressure. Then measure flow (and FP) @ max boost by putting pressure on the regulator (bicycle pump or so)
#1175 CHILL Gone DUTCH
Posted 23 July 2013 - 10:12 AM
Hi nick, Did you do a learn session on the way home, How are you getting on with it all. Or are you just having a rest from it all
#1176 NickB787
NickB787
  • 7,813 posts
Posted 23 July 2013 - 10:24 AM
I did a learn session Peter asked to see it so I emailed it to him.
Your right I am having a couple of days off as really fed up at present, the thought yet again of dropping the undertrays, wheel arch liners,
removing the starter (a pain of a job) just to check the knock sensor, then I need to move the 044 pump from it's upright position to horizontal, hope that may help.
Do another run to see if that makes a difference, if not check fuel pressure, change both pumps, find why the secondary lambda is still not working.
o and work over the weekend.
#1177 CHILL Gone DUTCH
Posted 23 July 2013 - 10:31 AM
I did a learn session Peter asked to see it so I emailed it to him.    Your right I am having a couple of days off as really fed up at present, the thought yet again of dropping the undertrays, wheel arch liners, removing the starter (a pain of a job) just to check the knock sensor, then I need to move the 044 pump from it's upright position to horizontal, hope that may help.   Do another run to see if that makes a difference, if not check fuel pressure, change both pumps, find why the secondary lambda is still not working.  o and work over the weekend.
Keep me informed nick And you can give me a call at any time
#1178 NickB787
NickB787
  • 7,813 posts
Posted 23 July 2013 - 10:35 AM
thanks
#1179 Exmantaa
Posted 23 July 2013 - 12:00 PM
I would just do a FP check with the existing system before you start changing things...
#1180 siztenboots
Posted 23 July 2013 - 01:51 PM
also when doing anything like writing to the ECU make sure your car battery is fully charged and preferably laptop is mains powered
The other issue I found was having the ignition on for hours without running the engine , was that the coil pack killed itself.
