Ecu Change
1497 replies to this topic
#101 Winstar
Winstar
  • 4,264 posts
Posted 04 May 2011 - 09:43 AM
great thumbsup thanks
Just pluming the MAF in. someone mentioned the optimum distance from the TB, am searching now..
just noticed the coolant temp sensor has a different plug, so new sensor required, should run though
general rule of thumb is flow in a pipe will have recoved by 5x the internal diameter after a disturbance.
Edited by Winstar, 04 May 2011 - 09:43 AM.
#102 siztenboots
  • 26,613 posts
Posted 04 May 2011 - 09:46 AM
so 70mm x5 = 350mm , 80mm x5 = 400mm
is the throttle body upstream of the MAF , or vica versa?
#103 VIX
VIX
  • 9,497 posts
Posted 04 May 2011 - 09:49 AM
first start up tomorrow then? good luck buddy hope it goes smoothly!
:yeahthat: (although I suspect he's settle for it going roughly!) Good luck Nick. thumbsup
#104 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 04 May 2011 - 09:56 AM
MAF is upstream of the TB
#105 The Batman
Posted 04 May 2011 - 11:57 AM
hows it going nick? just woken up after a double shift and possibly think my head is still asleep :lol: sizten got any pictures of before and after your mods to the amm?
#106 siztenboots
  • 26,613 posts
Posted 04 May 2011 - 12:04 PM
the plastic grid and mesh just lever out with a screwdriver.
#107 NickB787
NickB787
  • 7,813 posts
Posted 04 May 2011 - 12:30 PM
got it all hooked up, had a bit of trouble with the alarm seems ok now, think the fob battery is low, it turns over but no spark, I tried another coil pack and still nothing, not certain the scangauge is connected properly, shows no faults Edit, throttle is working
Edited by NickB777, 04 May 2011 - 12:45 PM.
#108 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 04 May 2011 - 12:45 PM
Is the fuel pump priming and is the throttle body moving ? Does the scangage work on the turbo ecu ?
#109 The Batman
Posted 04 May 2011 - 12:46 PM
you have 2 z22yh coilpacks?! dont suppose you have the spark plug light tools do ya? goes between the plug and coilpack and lights up if they are getting a spark
#110 NickB787
NickB787
  • 7,813 posts
Posted 04 May 2011 - 12:49 PM
throttle is working with power applied, I had a z20let coil pack I had some plugs which I just took out so put all four in the coil pack, laying on the head and tried to start it, no spare from either pack no spark tool but I should be able to see if they are sparking
#111 siztenboots
  • 26,613 posts
Posted 04 May 2011 - 12:55 PM
there is a small spade connector on the loom that must be earthed to the ECU,
#112 NickB787
NickB787
  • 7,813 posts
Posted 04 May 2011 - 01:04 PM
has that thumbsup
#113 NickB787
NickB787
  • 7,813 posts
Posted 04 May 2011 - 01:46 PM
Just been checking I have no fuel pump pressure as well, my secondary pump is not powered either
#114 The Batman
Posted 04 May 2011 - 01:48 PM
is the first pump working? try pushing the fuel cut off switch thumbsup also got the right relays in :)
Edited by joe_589, 04 May 2011 - 01:48 PM.
#115 alanoo
alanoo
  • 1,324 posts
Posted 04 May 2011 - 01:56 PM
Immobilizer ?
#116 NickB787
NickB787
  • 7,813 posts
Posted 04 May 2011 - 02:10 PM
all relays are in, button pressed, when you turn the ignition on the pumps are not priming, also the fan is on until you crank the engine, that might be because of the lack of coolant sensor though
#117 NickB787
NickB787
  • 7,813 posts
Posted 04 May 2011 - 02:12 PM
Immobilizer ?
I have the ecu + 2 key chips ( 1 installed in my old key) + ignition unit so all should be paired up and alarm is not operating
#118 vocky
Posted 04 May 2011 - 03:21 PM
the crank sensor gives the signal to the ecu for the coilpack to fire however, relay K18 brown (five wires on base) powers the coilpack / fuel pump / relay K16 / various other stuff you should have +12v on pins 30 and 86 (comes from the fuse FL4 under the windscreen) pin 87 and 85 are the +12v outputs to the coilpack etc pin 85 is a switched negative from the ecu I would check the 12v is present and then you can earth out the pin 85 (K18) to check the relay is working
Edited by vocky, 04 May 2011 - 03:21 PM.
#119 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 04 May 2011 - 06:02 PM
I wonder if ecu was all good nick where did you but it from ? eBay it might not be matched chip and ecu :-((
#120 The Batman
Posted 04 May 2011 - 06:29 PM
got one you can borrow :)
