Ecu Change
1497 replies to this topic
#1181 CHILL Gone DUTCH
Posted 31 July 2013 - 03:35 PM
Any updates nick
#1182 VIX
VIX
  • 9,497 posts
Posted 15 August 2013 - 09:45 AM
:unsure:
#1183 CHILL Gone DUTCH
Posted 15 August 2013 - 10:08 AM
I think he will be back on it quite soon
#1184 VIX
VIX
  • 9,497 posts
Posted 15 August 2013 - 07:09 PM
thumbsup
#1185 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 16 August 2013 - 08:00 AM
Been away with the family for a few weeks, it's sim time again next week so everything stops for that. However more time off after that so the plan is to drop the under trays again, remove the starter and check the knock sensor, also need to check the exhaust as I am pretty certain that the back box is not tight, they could be the cause of the knock I seem to show at times. Check the fuel pressure, I brought a check unit and see why it seems a bit low at full chat.
#1186 CHILL Gone DUTCH
Posted 16 August 2013 - 08:04 AM
was it a smooth road surface when you did the runs nick, as this can also give wrong readings and knock
#1187 NickB787
NickB787
  • 7,813 posts
Posted 16 August 2013 - 08:20 AM
No not very which could also be part of the knock indications.
#1188 NickB787
NickB787
  • 7,813 posts
Posted 26 August 2013 - 09:54 AM
Well first bit of good news the car has not been run since the National and it started first time :D
up on ramps now, I have to go play golf today but will start in ernest tomorrow.
#1189 CHILL Gone DUTCH
Posted 26 August 2013 - 03:26 PM
Thumbs up I thought you got list in the simulator
#1190 NickB787
NickB787
  • 7,813 posts
Posted 27 August 2013 - 01:41 PM
ok so far so good, I tightened the exhaust back box up as one side was loose, both bolts were hand tight, one the rear I had to replace the nut, nice job, not.. Hope that was the reason for some knock being recorded, wouldn't have helped with 2 polly mounts either.
I managed to check the knock sensor without removing the starter motor, it's tail is now at 9.00 o'clock, only problem my torque wrench won't go down to 23nm.. any suggestions?
I will do a run as it is and try to check the fuel pressure at the same time.
#1191 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 27 August 2013 - 02:03 PM
Hurry up then I can nick your map lol
#1192 NickB787
NickB787
  • 7,813 posts
Posted 27 August 2013 - 03:26 PM
one step back, battery light on, 11.5v on scangauge looks like the alternator may have packed up, I was checking the fuel pressure 3.6 bar at idle, notices a slight drop when gently revving the engine need to run it properly at high power though.
need to sort the non charging first
#1193 NickB787
NickB787
  • 7,813 posts
Posted 27 August 2013 - 04:34 PM
I take it I need 100amp unit? what was the best option Autovaux or referb this one?
#1194 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 27 August 2013 - 04:59 PM
I have a spare 100amp nick if you want to borrow it
#1195 Exmantaa
Posted 28 August 2013 - 12:08 AM
you have a boost referenced fuel system? Standard NA regulator should be 3.8 bar with engine not running/vac tube disconnected from regulator, but about 0.7 lower @ idle.
Pressure + injector settings must be correcty for OBD to run well...
#1196 NickB787
NickB787
  • 7,813 posts
Posted 28 August 2013 - 05:10 AM
thanks for the figures will check it again
#1197 oakmere
oakmere
  • 2,143 posts
Posted 28 August 2013 - 09:02 AM
Nick As Vocky has said in the other thread, bet you have disturbed some if the alternator wiring. Things are tight as std even worse with the Harrop. I will be interested if the change in knock sensor position improves KR as mine produces more KR than expected at high rpm which has meant I have had to reduce ignition advance in the base map to remove it.
#1198 Exmantaa
Posted 28 August 2013 - 09:07 AM
Did you check your IAT on full chat? I've seen almost 90*C on heavy use...
#1199 oakmere
oakmere
  • 2,143 posts
Posted 28 August 2013 - 09:16 AM
Mine is N/A not SC. I think Nick was seeing high inlet temps not helped by his radiator fans running in reverse!
#1200 Nev
Posted 28 August 2013 - 09:30 AM
90 degrees is quite mental, goodness knows how much power you lose with the ignition retardation - do you know Exmanta ?
