Ecu Change
1497 replies to this topic
#1201 oakmere
oakmere
  • 2,143 posts
Posted 28 August 2013 - 09:42 AM
1 degree retard is roughly 2 bhp.
#1202 siztenboots
Posted 28 August 2013 - 09:45 AM
intake air temps are one thing , don't forget water temps also change the timing
#1203 Exmantaa
Posted 28 August 2013 - 09:47 AM
That are IAT's from a Harrop SC on the track... :blink: (but my M62 is not much lower!) Water injection to the resque.
Will see some proper power figures in October when we strap a few Dutch SC's on the dyno.
#1204 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 28 August 2013 - 10:43 AM
I could do with some real heavy runs, when I get the alternator problem sorted, but looking back on the logs I did after I got the fans turning the correct way :blush:  max inlet temp I show was 68C, Helps not heating the laminovas up from the main rad. I run with an inlet spacer, turbo ears and a large gap on the diffuser, might help disperse some of the heat.
I have now set up ready to go a water injection system just want to get the car running first, then will try pumping water at High rpm
water temps for me were fine 90C but yet again I need some REAL driving to check it out
Edited by NickB777, 28 August 2013 - 10:47 AM.
#1205 NickB787
NickB787
  • 7,813 posts
Posted 28 August 2013 - 11:00 AM
one step back, battery light on, 11.5v on scangauge looks like the alternator may have packed up, I was checking the fuel pressure 3.6 bar at idle, notices a slight drop when gently revving the engine need to run it properly at high power though.
you have a boost referenced fuel system? Standard NA regulator should be 3.8 bar with engine not running/vac tube disconnected from regulator, but about 0.7 lower @ idle.
Pressure + injector settings must be correcty for OBD to run well...
I am showing 3.4 bar not running
#1206 Exmantaa
Posted 28 August 2013 - 05:58 PM
Strange, as the OEM Z22SE pressure is around 3.8 bar... (56 or 58psi) Is your regulator adjustable?
If you run @ lower fuelpressure, the OBD injectortable must be compensated for that!
#1207 NickB787
NickB787
  • 7,813 posts
Posted 29 August 2013 - 03:20 PM
OEM unit, will try to borrow one to replace to one I have then try it again
#1208 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 29 August 2013 - 04:31 PM
I have a few pressure regulators Nick
#1209 VIX
VIX
  • 9,497 posts
Posted 29 August 2013 - 04:57 PM
Get thee to an airfield! thumbsup
#1210 NickB787
NickB787
  • 7,813 posts
Posted 30 August 2013 - 07:53 AM
Great will be in touch in a few days Lee, cheers
#1211 NickB787
NickB787
  • 7,813 posts
Posted 30 August 2013 - 07:54 AM
Very true with a smooth runway
#1212 siztenboots
Posted 30 August 2013 - 07:56 AM
blasting round heathrow perimeter road, till the airport police imposed a speed limit.
#1213 NickB787
NickB787
  • 7,813 posts
Posted 03 September 2013 - 02:08 PM
now where were we. New alternator coming tomorrow, PFR being borrowed from Lee, will try to get it running
#1214 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 03 September 2013 - 03:37 PM
If you know of a runway or similar we could use,i would love to smooth up my map and share the costs. We could make our own activity day...
#1215 fezzasus
Posted 03 September 2013 - 09:14 PM
+ me
#1216 NickB787
NickB787
  • 7,813 posts
Posted 04 September 2013 - 07:26 AM
where is there a smooth runway though?
I now have 2 alternators sat here  :huh: I ordered the new one then when I went to collect the original one they had already repaired it for me and as it has the 6 rib pulley on looks like thats going back on today, but not till I double check it with the new one to make certain the new one is correct.
I don't want it sat here as a spare if it's wrong.
Got a FPR form Lee yesterday so that will go on so I can check if there is any difference in FP between the two.
#1217 siztenboots
Posted 04 September 2013 - 07:30 AM
speak to one of the small airfields, cotswold, fairoaks , explain you want access to run up and down , at most for a duration of a few minutes per run, and say you are happy to move off for ATC.
#1218 NickB787
NickB787
  • 7,813 posts
Posted 04 September 2013 - 08:20 AM
Might try Cranfield biggest problem I know will be if they mention the word insurance
Edited by NickB777, 04 September 2013 - 08:21 AM.
#1219 siztenboots
Posted 04 September 2013 - 08:34 AM
runway lights , cars dropping oil / debris , all a pain . Maybe a trip up to Lincoln, some disused runways , reasonable surfaces.
#1220 VIX
VIX
  • 9,497 posts
Posted 04 September 2013 - 08:50 AM
Just some thoughts. Seems you've discounted Brunters so some other possibles. I did an MSE academy day at Upper Heyford years ago, no idea if the airfield track is still available. We did that training day at Alconbury with Ben - although I don't recall it being that smooth. Can Plans get you out at Dunsfold? chinky chinky
