Ecu Change
1497 replies to this topic
#1221 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 04 September 2013 - 09:02 AM
Just some thoughts. Seems you've discounted Brunters so some other possibles. I did an MSE academy day at Upper Heyford years ago, no idea if the airfield track is still available. We did that training day at Alconbury with Ben - although I don't recall it being that smooth. Can Plans get you out at Dunsfold? chinky chinky
I had thought about Alconbury I would need to find out how it has deteriorated over time.
PS  chinky chinky sounds like a good idea
#1222 VIX
VIX
  • 9,497 posts
Posted 04 September 2013 - 09:08 AM
Drop Ben an email and see if he still uses it and to let you know what it's like - I guess these contact details are current:
http://www.trackday-...ct-Details.html
#1223 siztenboots
Posted 04 September 2013 - 10:42 AM
ask walshy about north weald too
#1224 slindborg
Posted 04 September 2013 - 10:43 AM
you dont need a perfect surface, and imho a runway isnt long enough for some of the load sites.
Odds on it would be cheaper to simply get on a rolling road (and do the cal work yourself with the operator simply doing what you ask)
#1225 NickB787
NickB787
  • 7,813 posts
Posted 04 September 2013 - 11:28 AM
 very true
will check some prices
#1226 Kieran McC
Kieran McC
  • 3,416 posts
Posted 04 September 2013 - 11:46 AM
Nick how about Dave Walker at Emerald
#1227 slindborg
Posted 04 September 2013 - 12:44 PM
If hes up for it, Try Pete Baldwin at Wilshers Garage in Orwell. Hes old skool, you wont get curves as the RR is dial gauges :) but he can simply do what you want
#1228 NickB787
NickB787
  • 7,813 posts
Posted 20 September 2013 - 06:09 PM
we finally back from both work and holiday car is running alternator is working ok knock should be sorted with tightening the exhaust, need some tim enow to start some logging and some smooth roads for some power runs
#1229 Nev
Posted 20 September 2013 - 06:39 PM
Cool, hopefully you will fall back in love with the plastic thing :)
#1230 NickB787
NickB787
  • 7,813 posts
Posted 27 September 2013 - 02:28 PM
I posted on the checking fuel pressure thread about the fuel pressure here are the latest log, ps forget what I said about IAT's after a while they just go up!!
I upgraded to the latest version and put in 4.2 as static FP
#1231 techieboy
Posted 27 September 2013 - 02:36 PM
Ouch. The last 8 years worth of ignorance of IAT's on the usual SC conversion has been bliss.
What you really need is a smaller volume TVS supercharger (and maybe a 14" pulley). It's just trying to pump too much air into too small a space and as a result compressing the air in the inlet manifold and creating heat.
#1232 NickB787
NickB787
  • 7,813 posts
Posted 27 September 2013 - 02:38 PM
so that will be the tvs 2300 then :rolleyes:
or as we know a NEW larger intake manifold
#1233 techieboy
Posted 27 September 2013 - 02:46 PM
No, you need something more like a TVS-900. The 1320 is already shifting too much air, the 2300 would be trying to fire another litre of air in on top of what you've already got. :wacko:
#1234 NickB787
NickB787
  • 7,813 posts
Posted 27 September 2013 - 02:49 PM
yea but the 2300 you could use a smaller pulley so reduce the compression and heat (due compression)
#1235 CHILL Gone DUTCH
Posted 27 September 2013 - 02:52 PM
Starting to look better now nick but the inlet temps are high I would wait and see what peter says and then Think about cooling iat with your water injection But the air compression is that high I doubt it will do much good
Edited by CHILL Gone DUTCH, 27 September 2013 - 02:53 PM.
#1236 techieboy
Posted 27 September 2013 - 02:55 PM
There you go. An 18" pulley (I've got an alloy wheel here that you can use) on the end of the 2300 should drop the boost a bit and you'll be sorted,
Time to pull the laminova's out of the manifold altogether and see what effect that has? The increase in volume of the inlet manifold and reduction in compression as a result of that larger volume might outweigh the benefit of the laminovas.
#1237 CHILL Gone DUTCH
It's interesting how it's only after 100 (speeds ) That the iat go really high
#1238 CHILL Gone DUTCH
Posted 27 September 2013 - 02:57 PM
Have you done the power run
#1239 NickB787
NickB787
  • 7,813 posts
Posted 27 September 2013 - 03:05 PM
That is a really interesting idea Matt, drop the laminovas and add WI
yes Chill I thought I sent it you as a PM
#1240 techieboy
Posted 27 September 2013 - 03:08 PM
You've got the ability to do it, monitor it and map for it now, if you wanted to. If nothing else, it would be interesting to see what effect the laminova's do have at your level of power. Maybe just taking two out of the equation would show some changes, one way or the other. :unsure:
