Ecu Change
1497 replies to this topic
#1261 The Batman
Posted 22 May 2014 - 02:41 PM
Dude I may have one. Got a link to the part you won't and will have a look
#1262 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 22 May 2014 - 02:54 PM
Cheers Joe, however I ordered one earlier, am away AGAIN for 4 days so it will be here when I get back. that said most things should be fixed now put together time.
#1263 NickB787
NickB787
  • 7,813 posts
Posted 10 June 2014 - 08:10 AM
so legal again need to burn the slightly older fuel off then put some good stuff in and will then start having a look at the map again do we have a list of those with harrops, m62 and what other mods they have so it's a bit easier to get a base map up and running? map trading :-)
#1264 Bill SC
Bill SC
  • 344 posts
Posted 11 June 2014 - 11:46 AM
There's a list of the b207 conversions and some of us went Dutch. Haven't seen a separate list of Dutch users and specs though. http://www.vx220.org...ersions/page-20
#1265 NickB787
NickB787
  • 7,813 posts
Posted 11 June 2014 - 03:11 PM
had a look at Peter site and he has a forum so may be a place to dump our spec and pick up a base map?
did a couple of hours shake down run today looks like rear abs sensor wire is iffy as I lost the speedo I intend to bleed the brakes tomorrow so will check then
#1266 siztenboots
Posted 11 June 2014 - 03:18 PM
set up a dropbox share , plus you get change management built in
#1267 CHILL Gone DUTCH
Posted 11 June 2014 - 03:33 PM
Nick billsc has a Harrop on Dutch software Luke and chris_uk have to Don't no if it helps nick
Edited by CHILL Gone DUTCH, 11 June 2014 - 03:33 PM.
#1268 CHILL Gone DUTCH
Posted 11 June 2014 - 03:34 PM
I do have a copy of Luke's map if it's any good to you
#1269 NickB787
NickB787
  • 7,813 posts
Posted 11 June 2014 - 03:49 PM
Thanks That would be interesting to have a look at.
I think we will have to make a form up so people can enter the important information about their builds along with any maps they upload.
Will have a look into that Steve, thanks
once you have done the mapping/power runs and you want to go over again to triple check do you need to start from scratch or can it learn from previous logs? think I may have asked that some time ago
edit to attach file
Edited by NickB777, 11 June 2014 - 03:54 PM.
#1270 CHILL Gone DUTCH
Posted 11 June 2014 - 03:56 PM
Essentially you need to start again But you can just add learned data to replace the data in the fuel table, ie you could just relearn 0-4000rpm low load and just replace the figures in the fuel table at the same load at same rpm
#1271 CHILL Gone DUTCH
Posted 11 June 2014 - 04:04 PM
Im sure luke wont mind me sharing this with you
its the latest file i have of lukes,
#1272 CHILL Gone DUTCH
Posted 11 June 2014 - 04:05 PM
Please note nick these files are used at own risk,
#1273 NickB787
NickB787
  • 7,813 posts
Posted 11 June 2014 - 04:34 PM
cheers without me going over a stupid amount of stuff any idea what spec he has?
#1274 CHILL Gone DUTCH
Posted 11 June 2014 - 04:36 PM
Forged pistons rods Cams ( not sure which ) Harrop on a small pulley Porting 3" exhaust Phenolic spacer
Edited by CHILL Gone DUTCH, 11 June 2014 - 04:39 PM.
#1275 NickB787
NickB787
  • 7,813 posts
Posted 11 June 2014 - 04:38 PM
big difference will be the second sandwich plate cooler
#1276 CHILL Gone DUTCH
Posted 11 June 2014 - 04:40 PM
What do you mean by this nick,
#1277 NickB787
NickB787
  • 7,813 posts
Posted 11 June 2014 - 04:50 PM
doesn't Chris have the same extra cooling plate(water rad) that Lee has to keep the inlet temps down? rest sounds very similar to me Forged pistons, rods comp blower cams Harrop on a 2.9' Ported head, double valve springs 3" 2ublar exhaust with 4-1 manifold Phenolic spacer Balance shaft delete
Edited by NickB777, 11 June 2014 - 04:51 PM.
#1278 CHILL Gone DUTCH
Posted 11 June 2014 - 04:54 PM
No he has a direct air feed from the coupe
#1279 CHILL Gone DUTCH
Posted 11 June 2014 - 04:55 PM
Also this is Luke's map not chris s
#1280 NickB787
NickB787
  • 7,813 posts
Posted 11 June 2014 - 04:57 PM
:wacko: wrong one
:rolleyes:
